    Change background image based on time of day
    backgroundtimeofday
    18 Posts 5 Posters 9.2k Views 5 Watching
    • strawberry 3.141S Offline
      This should not work, as the getStyles function of the module gets just executed once when the mirror boots. I would suggest to create some classes like morning, afternoon, evening, … and in the module you load the css file with those classes, then create an interval which checks the current time of the day. based on that you query for the body like var body = document.querySelector('body'); and set the specific class body.className = 'morning';
      • I Offline
        I_Am_Anthony
        @I_Am_Anthony said in Change background image based on time of day:
        return [“normalBackground.css”];
        Can this be done in the getDom() function, or will that cause it to continually loop and eat up the processor? Apologies, I’m just getting into this and not 100% familiar with the program flow of execution. Something like this?
        Module.register("background", {
            defaults: {
        	night_start: 0,
                night_stop: 5,
                night_background: "ring.jpg",
                day_background: "Splash.png"
            getStyles: function() {
                return ["custom.css"];
            getDom: function() {
                var currentTime = new Date().getHours();
                if (having markup issues displaying logic) ){
                    body.className = night_background;
                else {
                    body.className = day_background;
          j.e.f.f Project Sponsor Module Developer @I_Am_Anthony
          @I_Am_Anthony getDom() is only executed when you call the updateDom() function. So in your code, you could have a timer that fires, say, every 10 minutes, and if the time threshold has passed, you can call updateDom().
          That said, your getDom() function needs to return something, as it expects to get the HTML update for the module from this routine, to be placed in whatever location the module is configured for. Since your module doesn’t have a configured location, using the getDom routine might not be the best place to do this.
          You can set all of this up in the start() function. Set up a timer, and in the function that gets executed when the timer fires, do your time comparison and update of the CSS class on the body element directly. No need to use getDom for this.
          • I Offline
            I_Am_Anthony
            How does this look?
                defaults: {
            	night_start: 0,
                    night_stop: 5,
                    night_background: "night.png",
                    day_background: "day.png"
                //Do I still need to load the custom.css?
                // Define start sequence.
                start: function() {
            	Log.info("Starting module: " + this.name);
            	// Schedule update interval.
            	var self = this;
                    self.updateBackground();
            	setInterval(function() {
            	}, 600000);
                updateBackground: function() {
                    if ( currentTime >= this.config.night_start && currentTime &#60= this.config.night_stop  ||
                       ((currentTime >= this.config.night_start || currentTime &#60= this.config.night_stop) &&
                        this.config.night_start > this.config.night_stop) ){
                        body.className = this.config.night_background;
                    else {
                        body.className = this.config.day_background;
            BTW, thanks for helping to walk me through this. I’m pretty rusty on javascript. If I can get it sorted and running, I’ll package it and submit it as a module. Not terribly useful, but hey…
            J strawberry 3.141S 2 Replies Last reply Reply Quote 0
              @I_Am_Anthony Looks like it might work! You should call updateBackground() once before setting up the timer so that you’ll have a background at module startup, instead of having to wait for the timer to fire for the first time.
                strawberry 3.141 Project Sponsor Module Developer @I_Am_Anthony
                @I_Am_Anthony night_background and day_background will be undefined.
                you have to address them like this.config.night_background and you have to change your comparison operators. => defines an arrow function and doesn’t mean greaer or equal then like >= would do. Less or equal would be `
                • I Offline
                  I_Am_Anthony
                  Good catch on the missing this.config.night_background, thanks.
                  I’m aware that it’s >= and &#60= The markup really hates the less than or equal sign together (because HTML apparently), so I just flipped them for the purposes of markup. Just found that I can use the escape instead: &#60=.
                  Anyway, thanks to both of you @j.e.f.f and @strawberry-3-141 for the help. I’ve updated the code above to prevent repasting. I’ll get it into the mirror soon to test. If it works then I’ll package it and submit as a module.
                  • X Offline
                    xTITUS MAXIMUSx
                    I know this is an old topic but did you get this module finished? if do you have a git hub?
                    • Piranha1605P Offline
                      Piranha1605
                      https://forum.magicmirror.builders/topic/13014/css-switch-module
                      X 1 Reply Last reply Reply Quote 0
                      • X Offline
                        xTITUS MAXIMUSx @Piranha1605
                        @Piranha1605
                        Not exactly what I am looking for. I tried to take @I_Am_Anthony code and tweak it to my needs but, no success. maybe you’ll review my code? :)
