    MMM-Facial-Recognition seems to run only once
    5 Posts 3 Posters 2.9k Views 3 Watching
      d00my
      Hello @all!
      First of all - thank you very much for your impressive work you are doing guys! Thank you very much for that.
      Now I am playing around with MM2 for 4 weeks and got almost all modules running.
      But now I´m facing troubles with MMM-Facial-Recognition. All steps in the readme of the module and module tools (MMM-Facial-Recognition-Tools) are successfully done for the first User.
      If I start MM2 on my Raspi 2 all modules are started without an error :
      1|mm       | > magicmirror@2.1.3 start /home/pi/MagicMirror
      1|mm       | > sh run-start.sh
      1|mm       |
      1|mm       | Starting MagicMirror: v2.1.3
      1|mm       | Loading config ...
      1|mm       | Loading module helpers ...
      1|mm       | No helper found for module: alert.
      1|mm       | Initializing new module helper ...
      1|mm       | Module helper loaded: updatenotification
      1|mm       | No helper found for module: clock.
      1|mm       | Module helper loaded: MMM-Facial-Recognition
      1|mm       | Module helper loaded: calendar
      1|mm       | No helper found for module: MMM-WunderGround24Hours.
      1|mm       | No helper found for module: MMM-GoogleMapsTraffic.
      1|mm       | Module helper loaded: MMM-EFA-departures
      1|mm       | Module helper loaded: newsfeed
      1|mm       | All module helpers loaded.
      1|mm       | Starting server on port 8080 ...
      1|mm       | Server started ...
      1|mm       | Connecting socket for: updatenotification
      1|mm       | Connecting socket for: MMM-Facial-Recognition
      1|mm       | Starting module helper: MMM-Facial-Recognition
      1|mm       | Connecting socket for: calendar
      1|mm       | Starting node helper for: calendar
      1|mm       | Connecting socket for: MMM-EFA-departures
      1|mm       | Starting node helper for: MMM-EFA-departures
      1|mm       | Connecting socket for: newsfeed
      1|mm       | Starting module: newsfeed
      1|mm       | Sockets connected & modules started ...
      1|mm       | Launching application.
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1715&itdDate=20171003
      1|mm       | Create new calendar fetcher for url: http://***/*** - Interval: 3600000
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1715&itdDate=20171003
      1|mm       | Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
      1|mm       | [MMM-Facial-Recognition] Facerecognition started...
      1|mm       | [MMM-Facial-Recognition] Loading training data...
      1|mm       | [MMM-Facial-Recognition] ALGORITHM: LBPH
      1|mm       | [MMM-Facial-Recognition] Training data loaded!
      1|mm       | [MMM-Facial-Recognition] --------------------
      1|mm       | [MMM-Facial-Recognition] Webcam ausgewählt...
      1|mm       | [MMM-Facial-Recognition] User undefined with confidence null logged in.
      1|mm       | [MMM-Facial-Recognition] User undefined logged out.
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1717&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1717&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1719&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1719&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1721&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1721&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1723&itdDate=20171003
      1|mm       | http://www.efa-bw.de/nvbw/XSLT_DM_REQUEST?name_dm=***&type_dm=any&useRealtime=1&line=gvh:***: :R&line=gvh:***: :R&outputFormat=json&mode=direct&limit=4&itdTime=1723&itdDate=20171003
      The time between the entry that the Webcam is used and “User undefined logged in” takes about 45 seconds.
      Here is the entry of my config.js regarding the MMM-F-R module:
      			module: 'MMM-Facial-Recognition',
      				// 1=LBPH | 2=Fisher | 3=Eigen
      				recognitionAlgorithm: 1,
      				// Threshold for the confidence of a recognized face before it's considered a
      				// positive match.  Confidence values below this threshold will be considered
      				// a positive match because the lower the confidence value, or distance, the
      				// more confident the algorithm is that the face was correctly detected.
      				lbphThreshold: 80,
      				fisherThreshold: 250,
      				eigenThreshold: 3000,
      				// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
      				useUSBCam: true,		//Original=false
      				// Path to your training xml
      				trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml',
      				// recognition intervall in seconds (smaller number = faster but CPU intens!)
      				interval: 2,	//Original=2
      				// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
      				logoutDelay: 10,
      				// Array with usernames (copy and paste from training script)
      				users: ['***'],
      				//Module set used for strangers and if no user is detected
      				defaultClass: "default",
      				//Set of modules which should be shown for every user
      				everyoneClass: "everyone",
      				// Boolean to toggle welcomeMessage
      				welcomeMessage: true
      It seems that the settings for recognition interval and logout delay are not interpreted after the first execution:
         			logoutDelay: 10,
      Any ideas what the reason for that behaviour could be?
      Output of lsusb:
      Bus 001 Device 005: ID 0c45:613b Microdia Win2 PC Camera
      Output camera settings:
      pi@mm2:~ $ v4l2-ctl -V
      Format Video Capture:
              Width/Height      : 640/480
              Pixel Format      : 'JPEG'
              Field             : None
              Bytes per Line    : 640
              Size Image        : 230990
              Colorspace        : JPEG
              Transfer Function : Default
              YCbCr/HSV Encoding: Default
              Quantization      : Default
              Flags             :
      The functionality of the webcam seems to be okay because I performed some tests with motion.
      Every suggestions are welcome!!
      Best
      d00my
        d00my
        Hi @all!
        Does somebody have a clue?
        Best
        d00my
        • P Offline
          paviro
          Try playing with the threshold. I’ve only used the module with the official pi cam and on my Mac so I cannot guarantee other cameras are working correctly.
          – The Doctor
            d00my @paviro
            @paviro
            Hi Paviro!
            Thank you for your response. I ordered a pi cam. Lets see what will happen.
            Best
            d00my
            • P Offline
              PrivatVoidMarmot @d00my
              @d00my Does it work now? I think I have an similar problem with the PiCam. I start the Magic Mirror and after selecting the camera nothing is happend. It doesn’t try do recognizie any user. I reinstalled all, and it worked ONCE… now I have the same problem like bevor. I tried intervall: 1, 2 and 5.
