    Can't make MMM-Paris-RATP-PG work
    13 Posts 5 Posters 8.4k Views 5 Watching
      AFCM
      Hello,
      Let me first say I’m not an programmer or a developper so my question might be easy to answer
      I started to build my magic mirror, modules work fine but I have some trouble to make MMM-Paris-RATP-PG work properly.
      I don’t know what I should put in the config part {
      I tested this and that from what I can find in the readme but nothing seems to work, I can’t even have something displayed on my monitor.
      I also tested MMM-LocalTransport but it doesn’t fit my needs, want to make it work so my son can use it before he goes to school, stuff like that
      I don’t need a very complex config, just to be able to see, like in the screenshot (https://github.com/da4throux/MMM-Paris-RATP-PG) one line with the bus number, next passage etc and then I will fill the module myself
      Thank you very much,
      da4throuxD 1 Reply Last reply Reply Quote 0
      • da4throuxD Offline
        da4throux @AFCM
        Hi @AFCM , so did you try something from the suggestions of the github readme file,
        like just with one bus for example:
        config:{
        busStations: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’}
        Would it be working on your setup ?
          AFCM @da4throux
          @da4throux Thank you, so I tried your config, I can only see the header nothing else. And the header shows “Connections, update request x S ago”
          This is what I have in my config.js :
          module: ‘MMM-Paris-RATP-PG’,
          position: ‘top_center’,
          header: ‘Connections’,
          config: {api: ‘v3’, type: ‘bus’, line: 38, stations: ‘observatoire+++port+royal’, destination: ‘A’
          I can use the module as a standalone right ? I don’t need anything else ?
            da4throux @AFCM
            @AFCM
            It sounds like a connectivity issue.
            1st step: Do the standard modules work: not setting the RATP, but for example the weather module ?
            2nd step: if it worked, then add the RATP module, also add ‘debug:true’ in the config also, and share the browser console, this will probably give some more hint.
              Jab
              I do have issue with the module, as it shows always “Loading Connection”
              here is my config:
              module: “MMM-Paris-RATP-PG”,
              position: “top_left”,
              header: “RATP”,
              busStations: [
              {type: “traffic”, line: [“rers”,“A”]},
              {type: “traffic”, line: [“metros”,“3”]},
              {type: “traffic”, line: [“metros”,“9”]}
              I’ve tested URL and they work fine. Any idea ?
              Regards,
              Jab
                Jab @Jab
                @Jab
                Reply to myself. Finally it works fine this morning, but I get this:
                A N/A
                3 N/A
                9 N/A
                I’ll continue to investigate…
                ChrisC da4throuxD 2 Replies Last reply Reply Quote 0
                • ChrisC Offline
                  Chris @Jab
                  @Jab
                  Hello,
                  If this can help you do your tests, I leave you the code of my config that works well on my mirror.
                  			module: "MMM-Ratp",
                  			header: "Bus 147 (vers Eglise De Pantin)", // le titre qui sera affiché en haut sur la configuration du widget
                  				apiURL: "https://api-ratp.pierre-grimaud.fr/v3/schedules/bus/147/mairie+de+livry+++gargan/R",
                  Regards,
                    da4throux @Jab
                    @Jab
                    Hi, thanks for giving the module a try.
                    the busStations element in your config seems to only as for traffic information, for those 3 lines.
                    N/A is typically what I get when there is no traffic in the night for example.
                    I checked with a similar config
                            module: 'MMM-Paris-RATP-PG',
                            position: 'bottom_right',
                            header: 'Test Config',
                              busStations: [
                    		        {type: 'traffic', line: ['rers','A']},
                                            {type: 'traffic', line: ['metros','3']},
                                            {type: 'traffic', line: ['metros','9']}
                              pluiePlaces: [{id: '751140', name: 'Home'}],
                              pluieUpdateInterval: 1 * 5 * 60 * 1000, //default is 10 minutes, make it 5 (minimum update time)
                    and get: three Traffic OK.
                    So that might have been the time you worked on it maybe ?
                    Out of curiosity how did you resolve your first issue of “Loading Connection” ?
                      da4throux @Chris
                      @Chris
                      just as a note, this is a config for a different module. To do a similar check with this module you would do:
                        position: 'top_left',
                        header: 'Chris',
                          busStations: [
                            {type: 'bus', line: 147, stations: 'mairie+de+livry+++gargan', destination: 'R'}
                      ChrisC 1 Reply Last reply Reply Quote 0
                      • ChrisC Offline
                        Chris @da4throux
                        @da4throux
                        Hello,
                        Indeed, sorry, I spoke too fast and I was wrong module.
                        I will try this configuration to see the result.
                        Regards,
                          Jab
                          Hi
                          Thanks all for your replies. Unfortunately, after the latest update to v2.2, MM does not start anymore. Seems to be an issue with electron.
                          I have to fix this and then I will try your different code samples.
                          Jab
                            Jab
                            Hi all,
                            Finally with a fresh install of v2.2, all modules work fine.
                            I think I’ll update a few the css in order to get a colored look & feel.
                            Thanks for your help,
                            Jab
                              Massi1990
                              bonjour,
                              voici ma config et rien ne fonctionne ? ecran noir ?
                              position: ‘top_left’,
                              header: ‘mairie de fresnes’,
                              busStations: [
                              {type: ‘bus’, line: 187, stations: ‘mairie+de+fresnes’, destination: ‘R’}
