    MMM-Netatmo-Thermostat
    13 Posts 5 Posters 7.2k Views 5 Watching
    • O Offline
      overflOw11
      Hello !
      Based on the MMM-Nest module, I write a new module for my Netatmo thermostat.
      Description
      This module is a very simple one. It only display a circle with the current temperature in it. The color of this circle changes according to the state of the thermostat.
      • thermostat is heating up : the circle is orange,
      • thermostat is not heating up, the circle is blue,
      • thermostat is off, the circle is grey.
      Download
      • zdenekZ Offline
        zdenek
        that’s great idea, thanks. Thank you for your your job. But for some reason, it doesn’t work for me. The error is
        Failed to load resource: the server https://api.netatmo.com/api/getthermostatsdata?access_token=xxxxxxxxxxxxxx|yyyyyyyyyy responded with a status of 403 (Forbidden)
        I’ve run curl --data "grant_type=password&client_id=MY_ID&client_secret=MY_SECRET&username=MY_LOGIN&password=MY_PASS" "https://api.netatmo.com/oauth2/token"
        and get
        {"access_token":"ACCESS_TOKEN","expires_in":10800,"expire_in":10800,"scope":["read_station"],"refresh_token":"REFRESH_TOKEN"}
        But the ACCESS_TOKEN from what I’ve get is not the same as the access_token from the error message.
        my config:
             		 module: 'MMM-Netatmo-Thermostat',
                	 position: 'top_right',
        			   clientId: "CLIENT_ID",
        			   clientSecret: "CLIENT_SECRET",
        			   refreshToken: "REFRESH|TOKEN",
        			   updateInterval: 600000
        What I did wrong? I’ve copied/pasted all tokens, so typo-error shouldn’t be the problem
        thanks
        Zdeněk
        • O Offline
          overflOw11
          @zdenek said in MMM-Netatmo-Thermostat:
          0000
          Hi @zdenek.
          I can reproduce your issue in my Mirror.
          It’s my fault, I didn’t set the good parameters in my curl command.
          Please retry the curl command and add the scope parameter at the end of the request :
          curl --data "grant_type=password&client_id=MY_ID&client_secret=MY_SECRET&username=MY_LOGIN&password=MY_PASS&scope=read_thermostat" "https://api.netatmo.com/oauth2/token"
          Copy the refresh token in your mirror’s configuration file and reload the mirror. You should have your thermostat information.
          Let me know if it’s working.
          overflOw11
          zdenekZ 1 Reply Last reply Reply Quote 0
          • zdenekZ Offline
            zdenek @overflOw11
            @overflOw11 cool, thanks. even it seems the refresh token is as the same as previous, it works. Just some questions
            • to change the color I can use CSS?
            • do you plan to add more info from termostat (the time of next change based on the schedule, what is the “setpoint” temperature for actual schedule,…)
            but that’s great, thanks
            Zdeněk
            • O Offline
              overflOw11 @zdenek
              Perfect !
              Yes you can change the color through the CSS file.
              And yes I plan to add more information about the thermostat in this plugin. For now, it’s a very simple module but it will be improved with time.
              When you ask me if you can change colors, I think about put colors of the module in configuration for example.
              Let me know if you think about something else.
              overflOw11
              • zdenekZ Offline
                zdenek @overflOw11
                @overflOw11 great. For me will be great, easy change color, also easy change of size of the circle, the align (seems to be to left, but I’ve it on the right side of screen) and definitely more infos. For example, I’ve the Thermostat in “away” state. Would be nice to see it on MM. Now I can see actual temp and state of thermostat, but without any idea, what shoudl be … for example-actual is 19 Celsius, Thermostat is off, but it’s ok, cause based on Schedule, temp should be not lower than 17 Celsius.
                I plan to buy and install Netatmo valves - do you plan to develop module also for this?
                but it’s great, thanks
                Zdeněk
                • O Offline
                  overflOw11
                  I just push an update to change easily the color of the circle.
                  I will working on other features soon but for your information, I don’t have Netatmo valves so I don’t plan to develop module for this now.
                  • zdenekZ Offline
                    zdenek @overflOw11
                    @overflOw11 excelent job. Is is possible to use HEX code of colour or just defined string?
                    one more thing - hot change aligment? 0_1512747996642_c7e5ee5a-6c1f-49b3-9bde-1a54db7ffc4f-image.png
                    as you can see, I’ve itn the right coloumn of screen and would be nice to have it aligned to center, or to right
                    thanks, Zdeněk
                      Smotx
                      This post is deleted!
                        Smotx
                        Je ne sais pas pourquoi, mais ce module fait ‘bug’ le module ‘MMM-Pages’
                        Lorsqu’on met en place ce module, ‘MMM-Pages’ ne change plus de page, ou change de page mais ne change pas l’affichage.
                        Dommage.
                        this module does not work with ‘MMM-Pages’.
                        if this module is active ‘MMM-pages’ no longer changes page
                        • ? Offline
                          A Former User
                          with MM 2.5 it doesn’t work to me.
                          Nothing is shown and no errors
                          • E Offline
                            enuzzo
                            • E Offline
                              enuzzo
