    MMM-Netatmo-Thermostat
    13 Posts 5 Posters 6.9k Views 5 Watching
    • zdenekZ Offline
      zdenek @overflOw11
      @overflOw11 great. For me will be great, easy change color, also easy change of size of the circle, the align (seems to be to left, but I’ve it on the right side of screen) and definitely more infos. For example, I’ve the Thermostat in “away” state. Would be nice to see it on MM. Now I can see actual temp and state of thermostat, but without any idea, what shoudl be … for example-actual is 19 Celsius, Thermostat is off, but it’s ok, cause based on Schedule, temp should be not lower than 17 Celsius.
      I plan to buy and install Netatmo valves - do you plan to develop module also for this?
      but it’s great, thanks
      Zdeněk
      • O Offline
        overflOw11
        I just push an update to change easily the color of the circle.
        I will working on other features soon but for your information, I don’t have Netatmo valves so I don’t plan to develop module for this now.
        zdenekZ 1 Reply Last reply Reply Quote 0
        • zdenekZ Offline
          zdenek @overflOw11
          @overflOw11 excelent job. Is is possible to use HEX code of colour or just defined string?
          one more thing - hot change aligment? 0_1512747996642_c7e5ee5a-6c1f-49b3-9bde-1a54db7ffc4f-image.png
          as you can see, I’ve itn the right coloumn of screen and would be nice to have it aligned to center, or to right
          thanks, Zdeněk
            Smotx
              Smotx
              Je ne sais pas pourquoi, mais ce module fait ‘bug’ le module ‘MMM-Pages’
              Lorsqu’on met en place ce module, ‘MMM-Pages’ ne change plus de page, ou change de page mais ne change pas l’affichage.
              Dommage.
              this module does not work with ‘MMM-Pages’.
              if this module is active ‘MMM-pages’ no longer changes page
                A Former User
                with MM 2.5 it doesn’t work to me.
                Nothing is shown and no errors
                • E Offline
                  enuzzo
                  • E Offline
                    enuzzo
