MagicMirror² v2.14.0 is available! For more information about this release, check out this topic.
Custom size of modules
Hi all,
I am new to Magicmirror, just finished my own mirror.
However, I´m runing in some trouble regarding the size of the modules - some of them overlap. So how can I adjust the size of my modules?
For example, how can I resize MMM-Fuel being displayed smaller?
Currently, I m using the default values.Thanks!
in folder
css
you find a file namedcustom.css
with this content:/***************************************************** * Magic Mirror * * Custom CSS * * * * By Michael Teeuw http://michaelteeuw.nl * * MIT Licensed. * * * * Add any custom CSS below. * * Changes to this files will be ignored by GIT. * *****************************************************/ body { }
There you can add anything you want to. In your example you could add this below the current content, not inside the body part!
.MMM-Fuel { width: 200px; }
Play around with the numbers to adjust to your layout
Thanks! I ´ll give it a try.
