    Modules stop work over time
    20 Posts 4 Posters 14.7k Views 2 Watching
    • L Offline
      lali
      I made a npm debug, if thats what you mean… Heres is some error, but I don’t know how to fix or if it is this making the troubles…
      1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
      2 info using npm@3.10.6
      3 info using node@v6.4.0
      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
      5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
      5 verbose stack at Error (native)
      6 verbose cwd /home/pi
      7 error Linux 4.4.19-v7+
      8 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start” “dev”
      9 error node v6.4.0
      10 error npm v3.10.6
      11 error path /home/pi/package.json
      12 error code ENOENT
      13 error errno -2
      14 error syscall open
      15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      16 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      16 error enoent This is most likely not a problem with npm itself
      16 error enoent and is related to npm not being able to find a file.
      17 verbose exit [ -2, true ]
      KirAsh4K 1 Reply Last reply Reply Quote 0
      • L Offline
        lali
        In mm-out.log I find this
        Whoops! There was an uncaught exception…
        • KirAsh4K Offline
          KirAsh4 Moderator @lali
          @lali said in Modules stop work over time:
          You are attempting to run it from the /home/pi folder instead of /home/pi/MagicMirror/ …
          • L Offline
            lali @KirAsh4
            @KirAsh4 But why does it work at first and then not?
            My mm.sh looks like this:
            cd ~/MagicMirror
            DISPLAY=:0 npm start
            Where and how must I make a change?
            • KirAsh4K Offline
              KirAsh4 Moderator
              Thing is, once it’s up and running, things just remain in memory and run. The only time it will restart is if the entire thing crashes. But you can check on that by typing in 'pm2 list' and look at the restarts column. If you are seeing a lot of restarts, then something else is going on that’s causing it to crash. Mine’s been running stable for the past almost 30 days now (I haven’t been active on my mirror with coding nor updates, life took over.)
              How things stop, specifically data being requested, is if there is a momentary network issue that the task could not reach the internet. However, even that will rectify itself at the next poll … If I disconnect my rpi from the network, eventually things like the calendar, newsfeed, and weather will all stop responding. When I reconnect it, they will all eventually refresh and start working again. So I don’t know what could be causing yours to simply quit.
              • L Offline
                lali @KirAsh4
                @KirAsh4 The only restarts it shows is my manual restarts with pm2 restart mm command. Otherwise it does not crash. The modules just stop answer. And at the same time the news-ticker still works…
                Could it be so that the memory is overflooded somehow?
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  Not unless you have a bunch of other stuff running on your rpi. What happens if you run only the default configuration and modules? Do any of those stop responding after a while, and what exactly happens, what does the display say or do?
                  • L Offline
                    lali @KirAsh4
                    @KirAsh4 The only thing i run besides MM is Pi-hole.
                    The Scrobbler-plugin has never lived for a longer time. It works for a few songs, maybe an album and when a song ends it just disappears. No error messages or something on the screen. If i pm2 restart mm it again, it works for a few songs again.
                    When RandomPhoto stops working, it freezes on an image, like it comes to an end of a stack. (Maybe it does?)
                    Clock and news seems to work all the time.
                    Could it be that file package.json?
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      Yeah, neither of those are default packages (that I could help you with.) Perhaps this is something you need to take to the respective authors and have them help you track down what the problem could be. It sounds like MM and its default modules are working just fine, so this is something that happens outside of it (specifically with those modules you mentioned.)
                      As a side query: why do you need pi-hole on the rpi? None of the default modules display ads, unless you’re actively using the rpi as a desktop computer and browse the internet with it.
                      • L Offline
                        lali @KirAsh4
                        @KirAsh4 Well, I suppose that is my next step then…
                        I use it to block out ads throughout my network. I set it as a dns in the router. It filters ads quiet nice. From web and in apps.
                        The MM install was to make use of my display I bought with some nifty information.
