    Dutch Rainforecast graph (Buienradar)
    3 Posts 2 Posters 3.5k Views 2 Watching
    • cirdanC Offline
      cirdan
      Based on a Dutch public api for rain forecast (BuienRadar).
      alt text
      More info on Github
      Config options
      The following properties can be configured:
      First Header Second Header
      lat the latitude of your location
      lon the longitude of your location
      width controls the size of the module
      height controls the size of the module
      lineWidth the thicknes of the line
      lineColor the color of the line
      fillColor the color of the area under the line
      maxPower the maximum number on the y axis
      rainText The text you want to display in front of the last time received in the last call
      noRainText the text you want to display if no rain is expected untill the last time in the last call.
      nrOfTimeLabels optional value, adds a number of time labels under the graph, advised values: 2-5. If non existant or 0 reverts to default behaviour.
      Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
      • G Offline
        goprojojo
        Hi, All I’m getting is this graph. Using the default module settings.
        • cirdanC Offline
          cirdan
          Looks smaller than expected, are width and height set correctly in the config?
