    MMM-SwissStationboard
    12 Posts 5 Posters 7.4k Views 6 Watching
    • V
      vanhoekd 0 Module Developer
      Please post any trouble you have with the SwissStationboard module into this thread.
      • D
        DenateG
        Hi VanHoekd,
        Thanks for making the module, it was very clear to set up and I dont have a problem with it. I wanted to edit the module slightly so that the trains I cant catch because of the walking time arent shown, as I have quite a long walk to the station. Is that possible to do? If so could you walk me through it?
        Thanks a lot!
        • D
          doubleT Module Developer
          Looking at the code it seems like “unreachable” trains get the class “.darkgrey”. Without changing the code of the module, you can add this line to your MagicMirror/css/custom.css :
          div.module.MMM-SwissStationboard .darkgrey { display: none; }
          Going further:
          If you want to change the code and care about making it configurable, add hideUnreachable: true to the config of the module and hideUnreachable: false to the defaults in the module’s js. Similar to the other if switch, add this at line 105:
          if ((diff > this.config.minWalkingTime) || (diff < this.config.minWalkingTime && this.config.hideUnreachable != true)) {
              // all the code from the original for-loop from line 106 on
              // you can leave the if switch at line 110 - 120
              // this way the unreachable trains will be darkgrey via css when hideUnreachable is not active
              // shows trains:
              // if diff is greater than minWalkingTime (= reachable) OR
              // if diff is smaller than minWalkingTime AND hide is not true (is false)
          If you don’t care about config, default and css and want to change the code, just add an if switch at line 105 similar to line 110 but with switched signs < to >:
          if (diff > this.config.minWalkingTime) {
              // everything from the original for-loop from line 106 on
              // only adds results that have a diff greater than your minWalkingTime
              // you can leave out the if switch at line 110 - 120 in this case
          I didn’t test all of this, though.
          • D
            DenateG
            Thanks for your help! Your first suggestion works. It removes the unreachable ones; if the maximumEntries is 10 and 8 of the entries are unreachable then only 2 will be shown. I fixed this by just increasing the maximum entries.
            I tried the last suggestion, thinking this would bypass the maximumEntries problem but unfortunately, i couldnt get the code working.
            Anyway thanks for your help!
            • D
              Ah, yes of course, it will still only call the maximum number of entries. That’s a bit more challenging.
              • V
                I will try to integrate that possability in a future release. Please give me some time for that, because i go on holiday soon and i don’t know if i get to it untill then.
                • V
                  It is included in the Module, please go into the Modules/MMM-SwissStationboard folder and issue the following command
                  git pull
                  Now you can remove the line from your custom.css and you will always have the same amount of connections shown, just add the following line to your module configuration:
                  hideNotReachable: 1, //Will hide all the not reachable connections
                  I hope, this will help :)
                  • D
                    DenateG
                    This is great! Thanks a lot. I will try it when i get home.
                    • I
                      insofern
                      I have a question to the MMM-SwissCommute Module. Perhaps anyone can help me within this topic:
                      My code looks like this:
                      			module: 'MMM-SwissCommute',
                      			position: 'top_right',
                      			header: 'Winterthur - Zurich',
                      				to: 'Eschlikon', // Destination station
                      				maximumEntries: 2, // Max departures displayed
                      				minWalkingTime: 10, // Minimum time to get to the station
                      			header: 'Winterthur - Lausanne',
                      				to: 'Lausanne', // Destination station
                      				minWalkingTime: 10 // Minimum time to get to the station
                      And I hoped to get the two Modules in the top-right corner, one below another. But for some reason they appear next to each other without a space (see figure).
                      Does anyone know how to get the modules one below another?0_1524927274964_screen_mm.png
                      • V
                        Hi insofern,
                        After digging into my code (which did not explain your issue) i noticed, that you used another module. I wrote the MMM_SwissStationboard module and you are using the MMM_SwissCommute module. May I suggest moving your question to another thread?
                        • I
                          insofern @vanhoekd 0
                          @vanhoekd-0 thank you for your reply.
                          I thought to ask the question here, because you reference the swisscommute module on your GitHub page. Wanted to try my luck :)
                          But of course, feel free to move it to a more fitting place
                          • D
                            duxnobis
                            Hi. I still think it was a good question. I for example wanted to have twice your module one above the other. Say the first shows the bus connection and below the train. Or simply two different starting points. How can I write this? Thanks for this very helpful module by the way!
