    Fresh install MM2 RP3 wont start :(
    6 Posts 3 Posters 2.8k Views 2 Watching
    • P
      paddyhughes
      Hi I have installed MagicMirror2 5 times now and still get to the same issue of not starting up.
      Setup
      Raspberry pi 3
      Jessie Full
      Auto Installer MagicMirror
      I have used the Automatic Installer (Raspberry Pi Only!)
      OK the first time i used Raspbian Stretch Lite but then i moved to Raspbian Stretch Full wont start.
      After some googling i came across a link to install it with Raspbian Jessie Full
      complete-setup-tutorial
      Here is my
      npm-debug.log
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.12.3
      5 info lifecycle magicmirror@2.2.2~prestart: magicmirror@2.2.2
      6 silly lifecycle magicmirror@2.2.2~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.2.2~start: magicmirror@2.2.2
      8 verbose lifecycle magicmirror@2.2.2~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.2.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.2.2~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.2.2~start: Args: [ '-c', 'sh run-start.sh' ]
      12 silly lifecycle magicmirror@2.2.2~start: Returned: code: 1  signal: null
      13 info lifecycle magicmirror@2.2.2~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.2.2 start: `sh run-start.sh`
      14 verbose stack Exit status 1
      14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
      14 verbose stack     at emitTwo (events.js:106:13)
      14 verbose stack     at EventEmitter.emit (events.js:191:7)
      14 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      14 verbose stack     at ChildProcess.emit (events.js:191:7)
      14 verbose stack     at maybeClose (internal/child_process.js:920:16)
      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      15 verbose pkgid magicmirror@2.2.2
      16 verbose cwd /home/pi/MagicMirror
      17 error Linux 4.9.78-v7+
      18 error argv "/usr/bin/node" "/usr/bin/npm" "start"
      19 error node v6.12.3
      20 error npm  v3.10.10
      21 error code ELIFECYCLE
      22 error magicmirror@2.2.2 start: `sh run-start.sh`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.2.2 start script 'sh run-start.sh'.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error     sh run-start.sh
      23 error You can get information on how to open an issue for this project with:
      23 error     npm bugs magicmirror
      23 error Or if that isn't available, you can get their info via:
      23 error     npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      And a screen shot of my
      PM2 Info MagicMirror
      alt text
      I really hope you can help me thanks :):)
      • cruunnerrC
        cruunnerr
        @paddyhughes
        did u try it manually yet?
        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners/3
        Remove your actual MagicMirror folder and try it like described in the link
        P 1 Reply Last reply
        • P
          paddyhughes @cruunnerr
          @cruunnerr
          Hi Thanks for the suggestion. just followed them steps
          i am now getting the following errors when i run npm start
          err! Errno 1
          I have a second Sd Card i am going to try it on Raspbian Stretch Full and see if i can get it working
          Thanks for all the support guys
          • P
            paddyhughes
            Hi so it Just worked.
            i was logged in and installed MagicMirror in CLI mode
            Just before i decide to move to a new SD card i changed the CLI to GUI in sudo raspi-config
            and rebooted the pi once it logged it the MagicMirror kicked in after about 20seconds
            Did i do something wrong should i have always had the GUI enables and just worked in terminal
            if so. Sorry my bad…
            Also any way for the MagicMirror to start quicker with out seeing the GUI Desktop
            N 1 Reply Last reply
            • N
              ninjabreadman @paddyhughes
              @paddyhughes Yeah, MM relies on the GUI to display the browser. It’s possible to run without a GUI, but it requires some extra packages and effort. Sorry, didn’t think to ask, but glad to hear it’s up and running!
              Problem with config or JavaScript? Copy/paste it into JSHint.
              Check out the detailed walkthroughs on install, config, modules, etc.
              • P
                paddyhughes @ninjabreadman
                @ninjabreadman
                No i realy happy i got it working thanks everyone for all the help
                Alot of great support gong on in the forms
                Big Thumbs up to you all
