    Help with the camera
    16 Posts 3 Posters 7.9k Views 3 Watching
    • X Offline
      xela
      i’m getting all of that which I have no idea what it means but I think it is related to the voicecontrol:
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
      ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
      ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM front
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround21
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround40
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround41
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround50
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround51
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround71
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM iec958
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM spdif
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
      ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
      ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
      ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
      Cannot connect to server socket err = No such file or directory
      Cannot connect to server request channel
      jack server is not running or cannot be started
      JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
      N R 2 Replies Last reply Reply Quote 0
      • N Offline
        ninjabreadman @xela
        @xela Which modules are you using? Did you run npm install in both folders? Do you also have the camera module in your config.js?
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
        • X Offline
          xela
          thank you very much! it’s working!
          do you know by any chance if it’s possible to have the camera picture as vertically full screen?
          Or is not, is it possible to hide all other modules when the camera picture is on?
          I want to use the camera as my mirror so when I say the magic work everything disappears and only the camera picture stays.
          • N Offline
            ninjabreadman
            Have a look at MMM-pages. Install it, and you can then send a PAGE_CHANGED notification either when you send the camera notifications (voicecontrol module) or when you receive and process them (camera module). That should page between the camera and everything else.
            X 1 Reply Last reply Reply Quote 0
            • X Offline
              xela @ninjabreadman
              Thank you very much! That’s great.
              Do you know by any chance if it’s possible to have the camera image 90 degree rotated and on full screen? I want to use the camera as the mirror instead of applying a glass or a film.
              • N Offline
                ninjabreadman @xela
                @xela What modules are you using? ¯\_(ツ)_/¯
                • X Offline
                  xela
                  Sorry… the modules I’m using are:
                  Alert
                  updatenotification
                  helloworld
                  clock
                  calendar
                  MMM-WunderGround
                  MMM-Traffic
                  MMM-GoogleMapsTraffic
                  MMM-ImageSlideshow
                  voicecontrol
                  camera
                  compliments
                  newsfeed
                  MMM-Remote-Control
                  I also intend to use MMM-buttons so when I press a button it will start the image slideshow of artistic pictures (so it will act as a wall art).
                  thank you for your help!
                  N 2 Replies Last reply Reply Quote 0
                  • N Offline
                    ninjabreadman @xela
                    @xela It’s not supported natively by webcamjs. See this issue posted here. You can try CSS transforms, but it may be too processor intensive for the RPi.
                    • N Offline
                      ninjabreadman @xela
                      @xela Regarding rotating the camera, you can physically rotate the camera. If you’re directly connecting it to the RPi, consider using a flex cable instead.
                      • X Offline
                        xela
                        I am getting the following error:
                        Webcam.js Error: Could not access webcam: NotSupportedError: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV). NotSupportedError: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV).
                        Do you know by any chance what it means?
