    Help with the camera
    16 Posts 3 Posters 9.3k Views 3 Watching
    • N Offline
      ninjabreadman @xela
      @xela What modules are you using? This seems like voicecontrol, but what are you using for a camera module? Does it already include receivers for those notifications?
      • X Offline
        xela
        i’m getting all of that which I have no idea what it means but I think it is related to the voicecontrol:
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
        ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
        ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM front
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround21
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround40
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround41
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround50
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround51
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround71
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM iec958
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM spdif
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
        ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
        ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
        ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
        Cannot connect to server socket err = No such file or directory
        Cannot connect to server request channel
        jack server is not running or cannot be started
        JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
        N R 2 Replies Last reply Reply Quote 0
        • N Offline
          ninjabreadman @xela
          @xela Which modules are you using? Did you run npm install in both folders? Do you also have the camera module in your config.js?
          • X Offline
            xela
            thank you very much! it’s working!
            do you know by any chance if it’s possible to have the camera picture as vertically full screen?
            Or is not, is it possible to hide all other modules when the camera picture is on?
            I want to use the camera as my mirror so when I say the magic work everything disappears and only the camera picture stays.
            • N Offline
              ninjabreadman
              Have a look at MMM-pages. Install it, and you can then send a PAGE_CHANGED notification either when you send the camera notifications (voicecontrol module) or when you receive and process them (camera module). That should page between the camera and everything else.
              X 1 Reply Last reply Reply Quote 0
              • X Offline
                xela @ninjabreadman
                Thank you very much! That’s great.
                Do you know by any chance if it’s possible to have the camera image 90 degree rotated and on full screen? I want to use the camera as the mirror instead of applying a glass or a film.
                • N Offline
                  ninjabreadman @xela
                  @xela What modules are you using? ¯\_(ツ)_/¯
                  • X Offline
                    xela
                    Sorry… the modules I’m using are:
                    Alert
                    updatenotification
                    helloworld
                    clock
                    calendar
                    MMM-WunderGround
                    MMM-Traffic
                    MMM-GoogleMapsTraffic
                    MMM-ImageSlideshow
                    voicecontrol
                    camera
                    compliments
                    newsfeed
                    MMM-Remote-Control
                    I also intend to use MMM-buttons so when I press a button it will start the image slideshow of artistic pictures (so it will act as a wall art).
                    thank you for your help!
                    N 2 Replies Last reply Reply Quote 0
                    • N Offline
                      ninjabreadman @xela
                      @xela It’s not supported natively by webcamjs. See this issue posted here. You can try CSS transforms, but it may be too processor intensive for the RPi.
                      • N Offline
                        ninjabreadman @xela
                        @xela Regarding rotating the camera, you can physically rotate the camera. If you’re directly connecting it to the RPi, consider using a flex cable instead.
                        • X Offline
                          xela
                          I am getting the following error:
                          Webcam.js Error: Could not access webcam: NotSupportedError: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV). NotSupportedError: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV).
                          Do you know by any chance what it means?
                          • N Offline
                            ninjabreadman @xela
                            @xela Read through this issue on GitHub. Given you were trying to make the webcam full screen, is it related?
                              ricardoyen @xela
                              @xela
                              I’m getting the same error you noted
                              how did you overcome this error ??
