    Translation "After one month" in Calendar Module
    15 Posts 4 Posters 9.6k Views 3 Watching
      MM-Hans
      Can someone tell me where I can change the text “Over één maand” in the Calendar Module? It is my intention to replace it with “Over een maand” (in English something like “After one month”).
      • Y Offline
        yawns Moderator
        If I am not mistaken this text comes from moment.js using translations based on the locale you set. I guess you use dutch translation, right?
        • Y Offline
          yawns Moderator @yawns
          Yep, looks like I am right. This is found in moment.js locale settings. In this case it uses the future variable and M from relativeTime
          //! moment.js locale configuration
          //! locale : Dutch [nl]
          //! author : Joris Röling : https://github.com/jorisroling
          //! author : Jacob Middag : https://github.com/middagj
          var monthsShortWithDots$2 = 'jan._feb._mrt._apr._mei_jun._jul._aug._sep._okt._nov._dec.'.split('_');
          var monthsShortWithoutDots$2 = 'jan_feb_mrt_apr_mei_jun_jul_aug_sep_okt_nov_dec'.split('_');
          var monthsParse$3 = [/^jan/i, /^feb/i, /^maart|mrt.?$/i, /^apr/i, /^mei$/i, /^jun[i.]?$/i, /^jul[i.]?$/i, /^aug/i, /^sep/i, /^okt/i, /^nov/i, /^dec/i];
          var monthsRegex$4 = /^(januari|februari|maart|april|mei|april|ju[nl]i|augustus|september|oktober|november|december|jan\.?|feb\.?|mrt\.?|apr\.?|ju[nl]\.?|aug\.?|sep\.?|okt\.?|nov\.?|dec\.?)/i;
          hooks.defineLocale('nl', {
              months : 'januari_februari_maart_april_mei_juni_juli_augustus_september_oktober_november_december'.split('_'),
              monthsShort : function (m, format) {
                  if (!m) {
                      return monthsShortWithDots$2;
                  } else if (/-MMM-/.test(format)) {
                      return monthsShortWithoutDots$2[m.month()];
                  } else {
                      return monthsShortWithDots$2[m.month()];
              monthsRegex: monthsRegex$4,
              monthsShortRegex: monthsRegex$4,
              monthsStrictRegex: /^(januari|februari|maart|mei|ju[nl]i|april|augustus|september|oktober|november|december)/i,
              monthsShortStrictRegex: /^(jan\.?|feb\.?|mrt\.?|apr\.?|mei|ju[nl]\.?|aug\.?|sep\.?|okt\.?|nov\.?|dec\.?)/i,
              monthsParse : monthsParse$3,
              longMonthsParse : monthsParse$3,
              shortMonthsParse : monthsParse$3,
              weekdays : 'zondag_maandag_dinsdag_woensdag_donderdag_vrijdag_zaterdag'.split('_'),
              weekdaysShort : 'zo._ma._di._wo._do._vr._za.'.split('_'),
              weekdaysMin : 'zo_ma_di_wo_do_vr_za'.split('_'),
              weekdaysParseExact : true,
              longDateFormat : {
                  LT : 'HH:mm',
                  LTS : 'HH:mm:ss',
                  L : 'DD-MM-YYYY',
                  LL : 'D MMMM YYYY',
                  LLL : 'D MMMM YYYY HH:mm',
                  LLLL : 'dddd D MMMM YYYY HH:mm'
              calendar : {
                  sameDay: '[vandaag om] LT',
                  nextDay: '[morgen om] LT',
                  nextWeek: 'dddd [om] LT',
                  lastDay: '[gisteren om] LT',
                  lastWeek: '[afgelopen] dddd [om] LT',
                  sameElse: 'L'
              relativeTime : {
                  future : 'over %s',
                  past : '%s geleden',
                  s : 'een paar seconden',
                  ss : '%d seconden',
                  m : 'één minuut',
                  mm : '%d minuten',
                  h : 'één uur',
                  hh : '%d uur',
                  d : 'één dag',
                  dd : '%d dagen',
                  M : 'één maand',
                  MM : '%d maanden',
                  y : 'één jaar',
                  yy : '%d jaar'
              dayOfMonthOrdinalParse: /\d{1,2}(ste|de)/,
              ordinal : function (number) {
                  return number + ((number === 1 || number === 8 || number >= 20) ? 'ste' : 'de');
              week : {
                  dow : 1, // Monday is the first day of the week.
                  doy : 4  // The week that contains Jan 4th is the first week of the year.
            MM-Hans
            Thanks! And yes you’re right, it is Dutch. But what is the path to moment.js? I guess it is outside MagicMirror but could not find it :-(
            • Y Offline
              yawns Moderator
              The path is ~/MagicMirror/node_modules/moment/locale/nl.js
              Before making any changes to this file I reccomend making a backup of the file :)
                MM-Hans
                Thanks Stefan, I appreciate your help!
                • P Offline
                  pjkoeleman @MM-Hans
                  @MM-Hans said in Translation “After one month” in Calendar Module:
                  I answer this in Dutch because otherwise it will be difficult to explain. The used notation in moment.js is correct.
                  Getallen tot twintig (20) worden normalieter uitgeschreven. Op het getal een worden accenten geplaatst als het een telwoord is.
                  Uitzondering hierop is in samenstellingen met een worden geen accenten op de ee gezet, ook niet als het telwoord één bedoeld is.
                  Voorbeeld hiervan is eendagsvlieg.
                  Bron : onzetaal.nl
                  No reason to change this, why would you like to do this?
                    MM-Hans @pjkoeleman
                    @pjkoeleman
                    Thanks for your posting. When an event is over, let’s say, five weeks MM displays “één maand”. But in my opinion “één” means more exactly one month and not “een maand”. In English “one month” vs. “a month”. So I would like to change it. I have found two installs of moment.js and translated in both “één” to “een” but after rebooting and power off several times it was not translated on the mirror so far.
                    • Y Offline
                      yawns Moderator @MM-Hans
                      @MM-Hans
                      That’s strange. I will check on my mirror tomorrow
                        MM-Hans @yawns
                        @yawns
                        Possibly it is a browser cache problem, I use an Android tablet and a full screen browser within my mirror (http://192.168.2.xxx:8080). In that case there must be a way to refresh the MM tablet page, preferable from the MM install on the RPi. Something with “nocache”? I’m not sure…
                          barnosch
                          maybe a stupid question,
                          but why do you want to see a event on your mirror,
                          which was already one month ago?
                          Or if i did not catched the timeing correctly, why do you want to see events which are more then one month away?
                            MM-Hans
                            Think I translated wrong, writing “An event is over one month” I ment “An event is after one month” ;-)
                            • Y Offline
                              yawns Moderator
                              Okay MM-Hans. After looking at vendor.js I noticed moment.js is loaded from "moment.js" : "node_modules/moment/min/moment-with-locales.js",
                              So if you go ahead, open "~/MagicMirror/vendor/node_modules/moment/min/moment-with-locales.js", and scroll down to line 10649 (no, I’m not kidding) and change één to een you are good to go.
                                MM-Hans @yawns
                                @yawns said in Translation “After one month” in Calendar Module:
                                Hi Stefan. You almost need to be a digital detective to locate that phrases ;-) But finally the issue is solved, thanks for your assistance!
                                Y 1 Reply Last reply Reply Quote 1
                                • Y Offline
                                  You are welcome!
