    how to start an image slide show with a press of a button?
    10 Posts 2 Posters 4.6k Views 1 Watching
    • X Offline
      xela
      Hello,
      I would like to start an image slide show with a short press of a button and then stop the image slide show with a long press of a button.
      I have a button connected to pin 15 and I’ve tested with a python code that it works.
      I think that I need to use the MMM-Imageslideshow and the MMM-Buttons modules but I don’t know how to configure them to work as described.
      Can someone please help?
      thank you!
      • cruunnerrC Offline
        cruunnerr
        @xela
        As i can see there is no image module which allows sending/receiving notifications.
        but how about just hide and how the module?
        U would need MMM-RemoteControl, too.
        MMM-Buttons:
        		    module: 'MMM-Buttons',
        			maxShortPressTime: 1000,
        		        buttons: [
        		                pin: 15,
        		                shortPress: {
        		                    notification: "REMOTE_ACTION",
        		                    payload: {
                                    action: "SHOW",
                                    module: "module_0_MMM-ImageSlideshow"
                                  longPress: {
                                  payload: {
                                  action: "HIDE",
        edit:
        the module_0_MMM-ImageSlideshow means, that this module is on the first position in your config.js.
        So u need to count to this module beginning with 0.
        If the module is at third position in your config it would be module_2_MMM-ImageSlideshow
        • X Offline
          xela
          Thank very much, but it didn’t work.
          the button definitely working outside MM (tested it with Python code).
          Also, is it possible to start the MMM-imageslideshow as hidden?
          Here is my config:
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	port: 8080,
          	ipWhitelist: [], // Set [] to allow all IP addresses
          	language: "en",
          	timeFormat: 12,
          	units: "metric",
          			module: 'MMM-ImageSlideshow',
          			position: 'bottom_left',
          				imagePaths: ['modules/MMM-ImageSlideshow/Images']
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'helloworld',
          			position: 'top_bar',	// This can be any of the regions.
          			classes: 'small bright',
          			text: 'The Modelevich family Magic Mirror, built by a very talented person!'
          			module: "clock",
          			position: "top_bar"
          			module: 'calendar',
                      position: 'top_left',
          			urgency: 0,
          			getRelative: 6,
          			fade: 'false',
                      timeFormat: 'absolute',
          			cssStyle: 'block', // block, clean, custom, (slate is for no mirror),
          						symbol: 'calendar-check-o ',
          						url: 'http://www.vic.gov.au/themes/v6/images/VictoriaCalendar-PublicHolidays.ics'
          					{	// YOU GET THE FOLLOWING URL FROM YOUR GOOGLE CALENDAR PAGE
          						url: 'https://calendar.google.com/calendar/ical/public/basic.ics'
              		module: 'MMM-WunderGround', // Just for forecast w/css entry
              		position: 'top_right',
                  	apikey: '', // private; don't share!
                  	pws: 'pws:I', // Bentleigh East Weather Station - Very Cool
          			currentweather: 1,
                  	coloricon: true,
                  	hourly: '1',
                  	fctext: '1',
                  	fcdaycount: "7",
                  	fcdaystart: "0",
                  	hourlyinterval: "2",
                  	hourlycount: "1",
          			animationSpeed: 5000,
                  	alerttime: 10000,
                  	alerttruncatestring: "english:",
              		roundTmpDecs: 0,
              		UseCardinals: 1,
          			fade: false,
              		layout: "vertical",
          			windunits: "mph",
              		sysstat: "0"
          	        module: 'MMM-Traffic',
                      classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                          api_key: '',
                          mode: 'driving',
          				origin: '9 Tambet Street, Bentleigh east, Australia 3165',
          				destination: '96 Herbert Street, Northcote, Australia 3070',
          				arrival_time: '0900', //optional, but needs to be in 24 hour time if used.
          				route_name: 'Home to Work',
                          changeColor: true,
                          showGreen: false,
                          limitYellow: 5, //Greater than 5% of journey time due to traffic
                          limitRed: 20, //Greater than 20% of journey time due to traffic
                          traffic_model: 'best_guess',
                          interval: 60000, //2 minutes
                          showWeekend: true,
                          allTime: true,
                          width: '300px',
                          height: '300px'
                      module: 'MMM-GoogleMapsTraffic',
                          key: '',
                          lat: -37.7685637,
                          lng: 144.9943173,
                          height: '400px',
                          width: '550px',
          				zoom: 13,
          				disableDefaultUI: false
              		module: 'voicecontrol',
                  		models: [
                          	keyword: "Show Camera",
                          	description: "Say 'Show Camera' to display camera",
                          	file: "showCamera.pmdl",
                          	message: "SHOW_CAMERA"
                          	keyword: "Hide Camera",
                          	description: "Say 'Hide Camera' to hide camera",
                          	file: "hideCamera.pmdl",
                          	message: "HIDE_CAMERA"
                          	keyword: "Selfie",
                          	description: "Say 'Selfie' when camera is visible",
                          	file: "selfie.pmdl",
                          	message: "SELFIE"
          			module: 'camera',
              		position: 'fullscreen_above',
          			selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                  	emailConfig: {
                      service: 'gamil', // Email provider to use to send email with a photo.
                      auth: {
          			module: "compliments",
          			position: "lower_third"
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "The Age",
                                                          url: "http://feeds.theage.com.au/rssheadlines/top.xml",
                                                          title: "Sport",
                                                          url:  "http://www.theage.com.au/rssheadlines/sport/article/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true
          		        buttons: [
          		                pin: 18,
          		                shortPress: {
          		                    payload: {
                                      action: "HIDE",
                                    longPress: {
                                    payload: {
                                    action: "SHOW",
          		module: 'MMM-Remote-Control',
          		position: 'bottom_right'
            cruunnerr
            hmm…
            To start it hidden just open your remoteControl with http://YOUR.RASPBERRY.IP.ADDRESS:8080/remote.html
            Go to “Edit view” and hide the module. Then press “SAVE”
            Note: Every time you change your config u need to do this again ;)
            so now to your button problem…
            please try this:
            open a browser on your pc and type:
            http://YOUR.RASPBERRY.IP.ADDRESS:8080/remote?action=HIDE&module=module_0_ImageSlideshow
            http://YOUR.RASPBERRY.IP.ADDRESS:8080/remote?action=SHOW&module=module_0_ImageSlideshow
            This should hide and show the module as these are the comments which the remote control is using.
            If this works its probably a configuration problem with the PIN.
            note that:
            +-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
             | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
             |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
             |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5v      |     |     |
             |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
             |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 0 | IN   | TxD     | 15  | 14  |
             |     |     |      0v |      |   |  9 || 10 | 1 | IN   | RxD     | 16  | 15  |
             |  17 |   0 | GPIO. 0 |  OUT | 0 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
             |  27 |   2 | GPIO. 2 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
             |  22 |   3 | GPIO. 3 |  OUT | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
             |     |     |    3.3v |      |   | 17 || 18 | 0 | OUT  | GPIO. 5 | 5   | 24  |
             |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
             |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
             |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
             |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
             |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
             |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
             |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
             |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
             |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 1 | OUT  | GPIO.27 | 27  | 16  |
             |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
             |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
            Don’t know what type u are using (BCM, w-pi, physical ??)
            In your config you wrote Pin: 18, but in your first post u said 15…
            Maybe try another one. For example u could use GPIO 29, which is physically Pin 40, which is BCM Pin 21…
            So in your config u must write, that u are using Pin 21!
            • X Offline
              xela
              thank you so much for your help!
              so, by going to the http://YOUR.RASPBERRY.IP.ADDRESS:8080/remote.html and hiding the module, it works fine. under “edit view” when i slide it to hide the slideshow goes off and when i’m sliding it to on the slideshow goes on.
              however, both
              don’t work although I’m getting “success” message.
              cruunnerrC 1 Reply Last reply Reply Quote 0
                cruunnerr @xela
                @xela
                Ah sorry… the MMM was missing. should be this:
                http://your.raspberry.ip.address:8080/remote?action=HIDE&module=module_0_MMM-ImageSlideshow
                And
                http://your.raspberry.ip.address:8080/remote?action=SHOW&module=module_0_MMM-ImageSlideshow
                • X Offline
                  xela
                  works perfectly, thank you so much for your help!
                  and now to the ultimate question for me… Is it possible to start the camera on full screen by a press of a button?
                    cruunnerr
                    surely, but i don’t know what camera u mean^^
                    A security camera somewhere at your house or the RPi camera?
                    For security u could check this: https://github.com/shbatm/MMM-RTSPStream
                    for RPi cam u could check this: https://forum.magicmirror.builders/topic/603/camera-module
                    • X Offline
                      xela
                      I use a Microsoft round web cam that I’ve embedded into the frame and I’m using the camera module however the voice recognition is not very good so I wanted to start it with a press of a button, but I don’t know how and how to display the video vertically on full screen.
                        cruunnerr
                        So you use the camera module i posted?
                        unfortunately i don’t use this module, so i am maybe the wrong person to ask…
                        But i took a look at the webcam.js of the module and in line 46/47 the width and hight is defined.
                        Maybe u should play around with that…
                        https://github.com/alexyak/camera/blob/master/webcam.js
                        nano MagicMirror/modules/camera/webcam.js
                        also check the camera.js at line 62/63…
                        nano MagicMirror/modules/camera/camera.js
                        I don’t know if it would be necessary to set the resolution of the cam within raspbian… ?
                        To start the cam with a button u can even use the MMM-Buttons module. This should work, if i understand the camera-module correct ^^
                        		        buttons: [
                        		                pin: 15,
                        		                shortPress: {
                        		                    notification: "SHOW_CAMERA",
                                                        longPress: {
                                                        notification: "HIDE_CAMERA",
