    GIF update from URL with MMM-EyeCandy
    26 Posts 5 Posters 16.8k Views 5 Watching
    • M
      majdzik84 @ninjabreadman
      @ninjabreadman Could you please explain to the novice where to insert the code?
      ... // img creation, etc
      var getTimeStamp = new Date().getTime();
      img.src = "https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif?seed=" + getTimeStamp;
      pic.appendChild(img);
      wrapper.appendChild(pic);
      in which file?
      I want the camera snapshot to have a time stamp because without it the same photo is still there and I want to use it in the alert module
      You wrote in a different topic
      @chef The POST request isn’t sending it an image, it’s sending the URL to the image (e.g. http://192.168.2.18:9920/security/values/2). The problem is, it already has a cached copy of that image. I suggest you append a timestamp to trick electron into re-fetching the same image/resource.
      You want to pass it a URL-encoded value, so use %3F as ? and just append your timestamp, like so:
      http://192.168.2.48:8080/api/v1/modules/alert/show_ALERT?timer=10500&imageUrl=http://192.168.2.18:9920/security/values/2%3F
      {INSERT TIMESTAMP HERE}&imageHeight=220px
      I will be grateful for any help because I have been fighting for several hours.
        sdetweil @majdzik84
        @majdzik84 wherever u build the url to your photo, the key is to pass some changing value, so the cache will get the new unique data.
        the trick, is to pass a parameter to the server as part of the url, but the server is not expecting any parameters, and will ignore them
        parameters on a url come after the ?
        so newurl=
        “old_url?fake_parm_name=”+millisecond_timestamp
        moment().valueOf() will return the always unique millisecond_timestamp value
        the name of the parm doesn’t matter as the server of the image is not expecting it, and the caching check is simple. is the url the SAME as one we already have data for
        no, get new data
        • M
          majdzik84
          so newurl=
          Can you tell me exactly what I need to do to get it? I understand how this should work, but I can’t do it
          {INSERT TIMESTAMP HERE} - What should the variable I type {…} look like
            sdetweil @majdzik84
            @majdzik84 ok. it looks like you are using remote-control to send an alert request, which should display an image?
            is that correct?
            so the image url is
            'http://192.168.2.18:9920/security/values/2%3FimageHeight=220px%26someid='+moment().valueOf()
            note that I have made the imageUrl a literal and appended the timestamp
            you would still have to add the link for remote-control to the front
            • M
              majdzik84
              @sdetweil I am using the standard alert module to use an alert with an image.
              Below is exactly my code that works fine but I can’t include a variable.
              I am sending the command from home assistant via rest_command
              http://192.168.2.200:8080/api/module/alert/showalert?message=Drzwi%20gara%C5%BCowe%20s%C4%85%20otwarte&imageUrl=https://xxx.com/local/snapshots/front.jpg&imageHeight=600px
              is it correct because it doesn’t work?
              http://192.168.2.200:8080/api/module/alert/showalert?message=Drzwi%20gara%C5%BCowe%20s%C4%85%20otwarte&imageHeight=600px&imageUrl=https://xxx.com/local/snapshots/front.jpg%3Fsomeid='+moment().valueOf()
                sdetweil @majdzik84
                @majdzik84 said in GIF update from URL with MMM-EyeCandy:
                sorry, I don’t know how to make this work from home Assistant. I was making work from inside MM.
                u could edit the Remote-Control module when it receives an alert request and append the timestamp there
                but as u are not a coder, this will be difficult.
