New MagicMirror Version
Hi all,
If I try tu update via git pull, I get this error Message:
pi@raspberrypi:~/MagicMirror $ git pull
Entferne tests/unit/translations/same_keys.js
Entferne tests/unit/functions/class_spec.js
automatischer Merge von modules/default/currentweather/README.md
KONFLIKT (Inhalt): Merge-Konflikt in modules/default/currentweather/README.mdAutomatischer Merge fehlgeschlagen; beheben Sie die Konflikte und committen Sie dann das Ergebnis.I have deleted the Readme file and also do git reset --hard. But nothing helps.
What can I do to solve the Problem?
Regards
Daniel
what error you get, did you run git pull && npm install
I only do git pull. After this I get the error.
@ostfilinchen
what is the error after you have deleted the Readme filetry following
pm2 stop mm
then
and then
pm2 restart mm
@ostfilinchen
but you have deleted them, if not then please delete and try again
I don’t know what happens, but now there is no error
