    New MagicMirror Version
    7 Posts 2 Posters 2.5k Views 2 Watching
    • O Offline
      ostfilinchen
      Hi all,
      If I try tu update via git pull, I get this error Message:
      pi@raspberrypi:~/MagicMirror $ git pull
      Entferne tests/unit/translations/same_keys.js
      Entferne tests/unit/functions/class_spec.js
      automatischer Merge von modules/default/currentweather/README.md
      KONFLIKT (Inhalt): Merge-Konflikt in modules/default/currentweather/README.mdAutomatischer Merge fehlgeschlagen; beheben Sie die Konflikte und committen Sie dann das Ergebnis.
      I have deleted the Readme file and also do git reset --hard. But nothing helps.
      What can I do to solve the Problem?
      Regards
      Daniel
      • N Offline
        NoNameRo @ostfilinchen
        @ostfilinchen
        what error you get, did you run git pull && npm install
        • O Offline
          ostfilinchen
          I only do git pull. After this I get the error.
          • N Offline
            @ostfilinchen
            what is the error after you have deleted the Readme file
            try following
            pm2 stop mm
            then
            and then
            pm2 restart mm
            • O Offline
              ostfilinchen @NoNameRo
              @NoNameRo
              Same error. I had never change the readme.md from the currentweather…
              • N Offline
                @ostfilinchen
                but you have deleted them, if not then please delete and try again
                • O Offline
                  ostfilinchen
                  I don’t know what happens, but now there is no error
