    MMM-PIR-Sensor problems
    24 Posts 3 Posters 18.7k Views 3 Watching
      MadScientist
      Have you tried to set the timer potentiometer (Haltezeit in your picture) on the PIR-sensor to minimum? I have the very same PIR-sensors and they are working very well without any additional resistors.
        blebbens
        Ok, think, it is working… not perfectly, but working.
        Could you take a picture of your potent meters AND jumper ?
        Have set them both to the left position. Would help a lot.
        A lot of people are walking the way the mirror is mounted to the wall. Finally, I would like the mirror to switch on if a person stays in front of it for 10 seconds. Don’t know exactly how to do this.
        At the moment it switches on in 1 second.
          MadScientist @blebbens
          @blebbens alt text
          That’s a picture I took before mounting it to the wall. Taking a new picture will be a bit difficult now. Hope it helps.
          Btw, I don’t use the MMM-PIR-sensor module. Initially I did though and I didn’t change the jumper. The sensor is set to “high”, in case it’s not clear from the picture.
            blebbens
            I put the potentio meters to the left position - like in your picture.
            The screen switches on in seconds… looking for a possibility to turn it on if someone stands in front of the mirror for 10 seconds.
            Using MagicMirror-Display-Controller instead of MMM-PIR-SENSOR.
            Hope, this could be done using right “time” potentio meter. Not sure.
            • 3 / 3
