Navigation
    • Search
    Auto start MM
    Troubleshooting
    • J
      johnny_swindle last edited by
      I am following the instructions outlined here: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
      When I paste in the suggested code provided by PM2 an error is returned. I am a total Noob and not sure how to proceed. Here is the error:
      pi@mm1:~/MagicMirror $ sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
      [PM2] Init System found: systemd
      Platform systemd
      Template
      [Unit]
      Description=PM2 process manager
      Documentation=https://pm2.keymetrics.io/
      After=network.target
      [Service]
      Type=forking
      User=pi
      LimitNOFILE=infinity
      LimitNPROC=infinity
      LimitCORE=infinity
      Environment=PATH=/usr/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
      Environment=PM2_HOME=/home/pi/.pm2
      PIDFile=/home/pi/.pm2/pm2.pid
      ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
      ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
      ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
      [Install]
      WantedBy=multi-user.target
      Target path
      /etc/systemd/system/pm2-pi.service
      Command list
      [ 'systemctl enable pm2-pi',
        'systemctl start pm2-pi',
        'systemctl daemon-reload',
        'systemctl status pm2-pi' ]
      [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
      [PM2] Making script booting at startup...
      >>> Executing systemctl enable pm2-pi
      [DONE]
      >>> Executing systemctl start pm2-pi
      Job for pm2-pi.service failed because the control process exited with error code.
      See "systemctl status pm2-pi.service" and "journalctl -xe" for details.
      [ERROR] Exit code : 1
      [PM2][ERROR] systemctl start pm2-pi failed, see error above.
      Thanks in advance for any and all assistance.
      Johnny
