    MMM-MP3Player
    19 Posts 9 Posters 9.1k Views 9 Watching
    • asimhsiddA Offline
      asimhsidd
      Hi there,
      This is a module for playing music from USB pen drive as soon as it is inserted. A music player object is built inside the module, no iframe is used. The best position is bottom left, although it depends upon the user. The player has nice rounded and shadow borders which adds a nice aesthetic sense to the overall MM. The player then waits for the user to insert/attach a USB pen drive containing the MP3 files. As soon as a USB drive is plugged, the music starts playing!
      The module is built with error handling procedures. Feel fee to test it and let me know of any issues.
      Happy coding!
      Screenshot
      thats how it shows
      thats how it shows
      Download
      [card:asimhsidd/MMM-MP3Player]
      D 1 Reply Last reply Reply Quote 7
        Damian @asimhsidd
        @asimhsidd
        Just thinking aloud here about this…
        Portable HD… with some kind of powered switch/usb hub… smart socket/inline switch that can be voice activated by either the mirror itself through voice module, or by Alexa/Google Home to Turn on/off HD.
        Leave HD in place behind mirror to save having a USB extention lead dangling to insert/unplug USB Stick.
        Share that HD on the Pi, so you can add/change your MP3’s from another Source on your network?
        asimhsiddA 1 Reply Last reply Reply Quote 0
          asimhsidd @Damian
          @damian
          Good idea… I like the thought process. Personally I like to avoid dependence on any external switch/equipment simply because I cant test it as I am making these modules on office windows PC (:p). Also the fact I am not a seasonal programmer, so I have certain limitations.
          However, I am reading about how to connect with the PI through Bluetooth and steam music on the go from the cellphone. Help me if you can!
          Thanks.
          • T Offline
            themc
            got it to work on the latest build by lowering my node version to 57. however it works when i plug my usb in and then power on the pi but only then. not when the mirror is running and pluggin it in after or repluggin it in? any adive or pointers on how to fix that ?
              Artech
              @asimhsidd first of all thank you for your module it is really what i need for my mirror but i got a problem when i try to run it, in my terminal i have this
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘usb’
              so if you or another can help me i will be thankful
              • P Offline
                patrickirvin @Artech
                @Artech I have the same problem - while running npm install for dependencies I got the errors shown in screenshot - I suspect the install package needs updating.
                A S 2 Replies Last reply Reply Quote 0
                  Artech @patrickirvin
                  @patrickirvin so what will you do? for me this module is important but i put it in stand by first i’ll look on it after
                    sdetweil @patrickirvin
                    @patrickirvin the file needed is built locally on your machine…
                    but the stuff needed for the build is missing… do
                    sudo apt-get install libusb-1.0-0-dev
                    sudo apt-get install libudev-dev
                    then close the terminal window, re-open
                    and then do the npm install again
                    A P 3 Replies Last reply Reply Quote 0
                      Artech @sdetweil
                      This post is deleted!
                        Artech @sdetweil
                        @sdetweil itried t but what i got in my terminal when i use npm start is the same errors
                          sdetweil @Artech
                          @Artech ok, do this
                          cd ~
                          find /usr 2>/dev/null | grep libudev\.h
                          mine is in
                          /usr/include/libudev.h
                          after the two commands above
                          A 2 Replies Last reply Reply Quote 0
                          • P Offline
                            patrickirvin @sdetweil
                            @sdetweil Thanks! That got me past the errors when installing dependencies. Now when using npm start the MM exits when it hit the MMM-MP3Player part of the config file. I will look into the logs further.
                              Artech @sdetweil
                              @sdetweil thank i guive you a feedback later
                                @patrickirvin that usually means there is some other dependency missing
                                  Artech @sdetweil
                                  i got the same errors for this module
                                  • P Offline
                                    pillbug22
                                    Greetings
                                    Did you ever get MMM-MP3Player working? I was able to get it installed, running MagicMirror without issues (thank you to another post where we have to rebuild some stuff for newer node.js versions), and it shows the widget on the Mirror, but doesn’t do anything once a USB stick is plugged in.
                                    Also tried rebooting with the stick inserted, but does not play. Watching the console after
                                    npm run start
                                    shows it started the socket and started the MMM-MP3Player module, but no info is displayed when inserting the USB stick.
                                    X 2 Replies Last reply Reply Quote 0
                                    • X Offline
                                      x3mEr @pillbug22
                                      @pillbug22
                                      exactly the same situation. Was able to install with the help of https://stackoverflow.com/a/52796884
                                      Get no errors, but the module doesn’t see the USB stick.
                                      Find out, smth wrong with ‘drivelist’. Module can not get list of drives: it stucks at lines 27 and 42 in node_helper.js.
                                      • X Offline
                                        x3mEr @pillbug22
                                        @pillbug22, hi! Check it out: https://github.com/x3mEr/MMM-MP3Player.
                                        • E Offline
                                          emrah_asl
                                          Hi, How can I enable mp3 player only between 3 hours in a day ?
                                          05.00 AM - 08.00 AM
