    MMM-MP3Player
    19 Posts 9 Posters 8.7k Views 9 Watching
      sdetweil @Artech
      @Artech ok, do this
      cd ~
      find /usr 2>/dev/null | grep libudev\.h
      mine is in
      /usr/include/libudev.h
      after the two commands above
      A 2 Replies Last reply Reply Quote 0
      • P Offline
        patrickirvin @sdetweil
        @sdetweil Thanks! That got me past the errors when installing dependencies. Now when using npm start the MM exits when it hit the MMM-MP3Player part of the config file. I will look into the logs further.
          Artech @sdetweil
          @sdetweil thank i guive you a feedback later
            sdetweil @patrickirvin
            @patrickirvin that usually means there is some other dependency missing
              Artech @sdetweil
              i got the same errors for this module
              • P Offline
                pillbug22
                Greetings
                Did you ever get MMM-MP3Player working? I was able to get it installed, running MagicMirror without issues (thank you to another post where we have to rebuild some stuff for newer node.js versions), and it shows the widget on the Mirror, but doesn’t do anything once a USB stick is plugged in.
                Also tried rebooting with the stick inserted, but does not play. Watching the console after
                npm run start
                shows it started the socket and started the MMM-MP3Player module, but no info is displayed when inserting the USB stick.
                X 2 Replies Last reply Reply Quote 0
                • X Offline
                  x3mEr @pillbug22
                  @pillbug22
                  exactly the same situation. Was able to install with the help of https://stackoverflow.com/a/52796884
                  Get no errors, but the module doesn’t see the USB stick.
                  Find out, smth wrong with ‘drivelist’. Module can not get list of drives: it stucks at lines 27 and 42 in node_helper.js.
                  • X Offline
                    x3mEr @pillbug22
                    @pillbug22, hi! Check it out: https://github.com/x3mEr/MMM-MP3Player.
                    • E Offline
                      emrah_asl
                      Hi, How can I enable mp3 player only between 3 hours in a day ?
                      05.00 AM - 08.00 AM
