    MMM-MP3Player
    19 Posts 9 Posters 10.6k Views 9 Watching
      patrickirvin @Artech
      @Artech I have the same problem - while running npm install for dependencies I got the errors shown in screenshot - I suspect the install package needs updating.
      A S 2 Replies Last reply
      • A
        Artech @patrickirvin
        @patrickirvin so what will you do? for me this module is important but i put it in stand by first i’ll look on it after
          sdetweil @patrickirvin
          @patrickirvin the file needed is built locally on your machine…
          but the stuff needed for the build is missing… do
          sudo apt-get install libusb-1.0-0-dev
          sudo apt-get install libudev-dev
          then close the terminal window, re-open
          and then do the npm install again
          A P 3 Replies Last reply
          • A
            Artech @sdetweil
            • A
              Artech @sdetweil
              @sdetweil itried t but what i got in my terminal when i use npm start is the same errors
                sdetweil @Artech
                @Artech ok, do this
                cd ~
                find /usr 2>/dev/null | grep libudev\.h
                mine is in
                /usr/include/libudev.h
                after the two commands above
                A 2 Replies Last reply
                  patrickirvin @sdetweil
                  @sdetweil Thanks! That got me past the errors when installing dependencies. Now when using npm start the MM exits when it hit the MMM-MP3Player part of the config file. I will look into the logs further.
                  • A
                    Artech @sdetweil
                    @sdetweil thank i guive you a feedback later
                      @patrickirvin that usually means there is some other dependency missing
                      • A
                        Artech @sdetweil
                        i got the same errors for this module
                          pillbug22
                          Greetings
                          Did you ever get MMM-MP3Player working? I was able to get it installed, running MagicMirror without issues (thank you to another post where we have to rebuild some stuff for newer node.js versions), and it shows the widget on the Mirror, but doesn’t do anything once a USB stick is plugged in.
                          Also tried rebooting with the stick inserted, but does not play. Watching the console after
                          npm run start
                          shows it started the socket and started the MMM-MP3Player module, but no info is displayed when inserting the USB stick.
                          X 2 Replies Last reply
                          • X
                            x3mEr @pillbug22
                            @pillbug22
                            exactly the same situation. Was able to install with the help of https://stackoverflow.com/a/52796884
                            Get no errors, but the module doesn’t see the USB stick.
                            Find out, smth wrong with ‘drivelist’. Module can not get list of drives: it stucks at lines 27 and 42 in node_helper.js.
                            • X
                              x3mEr @pillbug22
                              @pillbug22, hi! Check it out: https://github.com/x3mEr/MMM-MP3Player.
                              • E
                                emrah_asl
                                Hi, How can I enable mp3 player only between 3 hours in a day ?
                                05.00 AM - 08.00 AM
