    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 869.4k Views 77 Watching
    • yawnsY Offline
      yawns Moderator @janner6
      @janner6
      did you remove or comment the position attribute?
          module: 'MMM-Remote-Control'
          // uncomment the following line to show the URL of the remote control on the mirror
          // , position: 'bottom_left'
          // you can hide this module afterwards from the remote control itself
        janner6 @yawns
        @yawns I totally forgot about this, thanks for the reminder. Exactly what I wanted.
        • SnilleS Offline
          Snille Module Developer
          @Jopyth I have lost the “Back” button on my remote see pic…
          Update: Just realized I have actually lost all the “icons”… :)
          I’m on the “development” branch (both on the mirror and on your module).
          I have recently reinstalled my mirror (today actually) but before that it worked…
          Have I missed something?
          If you cant find it, make it and share it!
          Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @Snille
            @Snille the icons got removed on the dev branch you have to run npm install in the magicmirror directory
            SnilleS 1 Reply Last reply Reply Quote 0
            • SnilleS Offline
              Snille Module Developer @strawberry 3.141
              @strawberry-3.141 Hmm… Can’t get it to work… Even deleted the “node_modules” before doing npm install in the mm dir, then also went in to the “vendor” dir and did the same… Still no pictures in the remote… However, I do get the “fontawesome” icons on other modules (my own included) so the pictures are there. :)
                @Snille https://github.com/Jopyth/MMM-Remote-Control/blob/master/remote.html#L10 uses the old path
                • SnilleS Offline
                  @strawberry-3.141 Oh! :) That’s why… Thank you.
                  • ? Offline
                    A Former User
                    Hey @Jopyth,
                    really like your module. By now, it works really cool with the standard definition. Now I try to hide single modules and I’m not so deep into configuring it.
                    Would you mind, to post a minimal example of your config file with the calendar show / hide example you have posted with gifs at the top?
                    That would be just perfect so I can see, how it’s working.
                    Thanks a lot
                    Patrick
                      McSorley
                      Just installed it and its working a treat! Thank you.
                      • K Offline
                        kurt
                        @Jopyth
                        strawberry helped me a lot! to install your modul and it works fine, just starting to play around with it. to install moduls in the future without taking care about missing kommas or [ or { or making mistakes by copying scripts, is a imendous help for people like me, who is absolut new to this javascriptpythonworld.
                        So thanks a lot and cheers
                        by now everything is running fine
                        Kurt
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 27
                        • 28
                        • 18 / 28
