    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 947.8k Views 77 Watching
    • A
      AAPS
      After updating MM from Remote-Control, when I rebooted I got a black screen. I realized that npm install was necessary, so everything works now. Only I thought that updating from Remote-Control would allow me to completely update without having to touch my mouse and keyboard. Is it supposed to?
      Mykle1M J 2 Replies Last reply
      Reply Quote 1
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @AAPS
        @Jopyth
        If you wouldn’t mind taking a look at this:
        https://forum.magicmirror.builders/topic/2188/mmm-remote-control-stopped-working-error
        I didn’t want to double post
        Reply Quote 1
        • G
          gshimself
          Dude, I just tried this for the first time.
          Holy shit, I love it! Nice work!
          • F
            fox
            @Jopyth have you changed something on the screen?
            Now on the devices the page losts the icons and back buttons etc.
            Tested on iOS, linux, laptop, handy, tablet. Everywhere the same effect:
            alt text
            strawberry 3.141S 1 Reply Last reply
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @fox
              @fox the module didn’t update the path to the icons that has changed in v2.1.1 yet.
              K F 2 Replies Last reply
              • K
                kurt @strawberry 3.141
                @strawberry-3.141
                how can we update the path?
                cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
                Thanke you
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @kurt
                  @kurt as far as i can see it is merged into the dev branch
                  to change to dev branch do the following
                  cd ~/MagicMirror/modules/MMM-Remote-Control
                  git fetch
                  git checkout develop
                  K 1 Reply Last reply
                  • F
                    fox @strawberry 3.141
                    @strawberry-3.141
                    What do you mean? That I can fix it with an update ?
                      A Former User
                      Can anyone post a example of his config, so I can see what to do to switch on/off the single modules? I only do have the default values there, shutdown etc…
                      Appreciate your help, thx
                      F 1 Reply Last reply
                      • F
                        fox @Guest
                        @PatrickGlatz
                        You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
                        So no need to change other modules configs
                        • K
                          @strawberry-3.141
                          thank you, the icons are here again :slight_smile:
                          I’ll try to install pm2 so I can use the New start and Switch off feature.
                          • P
                            pepemujica
                            Hi @Jopyth !
                            I’m trying to acces from my smartphone, but I have no answer.
                            From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
                            Kind regards
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @pepemujica
                              @pepemujica check your whitelist settings
                              P 1 Reply Last reply
                              • P
                                pepemujica @strawberry 3.141
                                @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
                                • strawberry 3.141S
                                  @pepemujica should be yes. When you enter from a device which gets blocked through the ipwhitelist you get a message in the logs
                                  P K 2 Replies Last reply
                                  • P
                                    @strawberry-3.141 Still can’t find the way, the whitelist is empty, I can access from the browser where it is installed the MM, but outside that I can’t, even being at the same wifi network :(
                                    • K
                                      @strawberry-3-141
                                      PM2 restart won’t work.
                                      Could you have a look, please.
                                      Thanks a lot
                                      [PM2] PM2 Successfully daemonized
                                      Use --update-env to update environment variables
                                      │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ watching │
                                       Use `pm2 show ` to get more details about an app
                                      [PM2][ERROR] Process mm not found
                                      { Error: Command failed: pm2 restart mm
                                          at ChildProcess.exithandler (child_process.js:218:12)
                                          at emitTwo (events.js:106:13)
                                          at ChildProcess.emit (events.js:191:7)
                                          at maybeClose (internal/child_process.js:877:16)
                                          at Socket. (internal/child_process.js:334:11)
                                          at emitOne (events.js:96:13)
                                          at Socket.emit (events.js:188:7)
                                          at Pipe._handle.close [as _onclose] (net.js:493:12) killed: false, code: 1, signal: null, cmd: 'pm2 restart mm' }
                                      pi@raspberrypi:~/MagicMirror $
                                      • strawberry 3.141S
                                        @kurt looks like there is currently no instance running that can be restarted so just start a new one by doing pm2 start mm
                                        • K
                                          @strawberry-3.141
                                          Thank you, this is what I get…
                                          pi@raspberrypi:~/MagicMirror $  pm2 start mm
                                          [PM2][ERROR] script not found : /home/pi/MagicMirror/mm
                                          pi@raspberrypi:~/MagicMirror $ pm2 show
                                            error: missing required argument `id'
                                          • strawberry 3.141S
                                            @kurt [PM2][ERROR] script not found
                                            did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
