    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • foxF
      fox @Guest
      @PatrickGlatz
      You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
      So no need to change other modules configs
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • K
        kurt @strawberry 3.141
        @strawberry-3.141
        thank you, the icons are here again :slight_smile:
        I’ll try to install pm2 so I can use the New start and Switch off feature.
          pepemujica
          Hi @Jopyth !
          I’m trying to acces from my smartphone, but I have no answer.
          From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
          Kind regards
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @pepemujica
            @pepemujica check your whitelist settings
            P 1 Reply Last reply
              pepemujica @strawberry 3.141
              @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
              • strawberry 3.141S
                @pepemujica should be yes. When you enter from a device which gets blocked through the ipwhitelist you get a message in the logs
                P K 2 Replies Last reply
                  @strawberry-3.141 Still can’t find the way, the whitelist is empty, I can access from the browser where it is installed the MM, but outside that I can’t, even being at the same wifi network :(
                  • K
                    @strawberry-3-141
                    PM2 restart won’t work.
                    Could you have a look, please.
                    Thanks a lot
                    [PM2] PM2 Successfully daemonized
                    │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ watching │
                     Use `pm2 show ` to get more details about an app
                    [PM2][ERROR] Process mm not found
                    { Error: Command failed: pm2 restart mm
                        at ChildProcess.exithandler (child_process.js:218:12)
                        at emitTwo (events.js:106:13)
                        at ChildProcess.emit (events.js:191:7)
                        at maybeClose (internal/child_process.js:877:16)
                        at Socket. (internal/child_process.js:334:11)
                        at emitOne (events.js:96:13)
                        at Socket.emit (events.js:188:7)
                        at Pipe._handle.close [as _onclose] (net.js:493:12) killed: false, code: 1, signal: null, cmd: 'pm2 restart mm' }
                    pi@raspberrypi:~/MagicMirror $
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @kurt
                      @kurt looks like there is currently no instance running that can be restarted so just start a new one by doing pm2 start mm
                      K 1 Reply Last reply
                      • K
                        @strawberry-3.141
                        Thank you, this is what I get…
                        pi@raspberrypi:~/MagicMirror $  pm2 start mm
                        [PM2][ERROR] script not found : /home/pi/MagicMirror/mm
                        pi@raspberrypi:~/MagicMirror $ pm2 show
                          error: missing required argument `id'
                        • strawberry 3.141S
                          @kurt [PM2][ERROR] script not found
                          did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                          • K
                            @strawberry-3.141
                            yes I did it following the steps in that wiki
                            • yawnsY
                              yawns Moderator
                              Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
                              So please go back one folder with cd .. or directly with cd ~ and try again
                              • K
                                kurt @yawns
                                @yawns
                                this is what I get,
                                do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
                                in my modules folder there is no PM2 folder. Should there be one?
                                Thanks a lot for help
                                kurt
                                pi@raspberrypi:~ $ npm start
                                npm ERR! Linux 4.4.50-v7+
                                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                npm ERR! node v6.10.0
                                npm ERR! npm  v3.10.10
                                npm ERR! code ENOENT
                                npm ERR! errno -2
                                npm ERR! syscall open
                                npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                npm ERR! enoent This is most likely not a problem with npm itself
                                npm ERR! enoent and is related to npm not being able to find a file.
                                npm ERR! enoent
                                npm ERR!     /home/pi/npm-debug.log
                                pi@raspberrypi:~ $  pm2 start mm
                                [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                [PM2][ERROR] script not found : /home/pi/mm
                                │ Name │ mode │ status │ ↺ │ cpu │ memory │
                                yawnsY 1 Reply Last reply
                                • yawnsY
                                  yawns Moderator @kurt
                                  @kurt
                                  If you want to start the process with npm start then you have to do that inside ~/MagicMirror
                                  However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                  pm2 seems to be working fine on your raspberry, so I would start here:
                                  Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
                                  cd ~
                                  nano mm.sh
                                  Add the following lines:
                                  DISPLAY=:0 npm start
                                  Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
                                  chmod +x mm.sh
                                  You are now ready to the MagicMirror using this script using PM2.
                                  • K
                                    kurt @yawns
                                    @yawns
                                    my first step was to make this start script following the instructions.
                                    the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
                                    When I try to start the mm by npm start I get this (the mirror is not appearing):
                                    { Error: listen EADDRINUSE :::8080
                                        at Object.exports._errnoException (util.js:1026:11)
                                        at exports._exceptionWithHostPort (util.js:1049:20)
                                        at Server._listen2 (net.js:1253:14)
                                        at listen (net.js:1289:10)
                                        at net.js:1399:9
                                        at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                        at process._tickCallback (internal/process/next_tick.js:98:9)
                                        at Module.runMain (module.js:592:11)
                                        at run (bootstrap_node.js:402:7)
                                        at startup (bootstrap_node.js:157:9)
                                      code: 'EADDRINUSE',
                                      errno: 'EADDRINUSE',
                                      syscall: 'listen',
                                      address: '::',
                                      port: 8080 }
                                    Thank you
                                    • yawnsY
                                      yawns Moderator
                                      EADDRINUSE means, there is another process running and listening on port 8080
                                      It looks like the magicmirror somehow is running already.
                                      • K
                                        kurt @kurt
                                        @yawns
                                        By now the PM2 does its work! Great!
                                        When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
                                        But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
                                        So by now some features work :slight_smile: some still need some time or a little push…
                                        Thank you
                                          pepemujica
                                          Hi @mochman !
                                          Is there any chance to change the caption that it is shown of each module?
                                          For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
                                          Is it possible to change the caption in the control?
                                          Kind regards
                                            Jopyth Moderator @AAPS
                                            Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
                                            Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
                                            [1.1.3] - 2017-04-23
                                            Added
                                            • Portuguese translation
                                            • Indonesian translation
                                            • Support for iOS Icon and Webapp
                                            Changed
                                            • Installation no longer needs a temporary file
                                            Fixed
                                            • Icon paths adapted to changes in Magic Mirror² 2.1.0
                                            Hopefully I got everyone covered in my answers:
                                            @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
                                            @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
                                            @AAPS You are right, I should probably add npm install after updating MM.
                                            @pepemujica What error do you get? Maybe it is something in your network settings?
                                            P ? 2 Replies Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
