    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • K
      kurt @strawberry 3.141
      @strawberry-3.141
      how can we update the path?
      cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
      Thanke you
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt as far as i can see it is merged into the dev branch
        to change to dev branch do the following
        cd ~/MagicMirror/modules/MMM-Remote-Control
        git fetch
        git checkout develop
        K 1 Reply Last reply
        • foxF
          fox @strawberry 3.141
          @strawberry-3.141
          What do you mean? That I can fix it with an update ?
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            A Former User
            Can anyone post a example of his config, so I can see what to do to switch on/off the single modules? I only do have the default values there, shutdown etc…
            Appreciate your help, thx
            foxF 1 Reply Last reply
            • foxF
              fox @Guest
              @PatrickGlatz
              You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
              So no need to change other modules configs
              • K
                @strawberry-3.141
                thank you, the icons are here again :slight_smile:
                I’ll try to install pm2 so I can use the New start and Switch off feature.
                  pepemujica
                  Hi @Jopyth !
                  I’m trying to acces from my smartphone, but I have no answer.
                  From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
                  Kind regards
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @pepemujica
                    @pepemujica check your whitelist settings
                    P 1 Reply Last reply
                      pepemujica @strawberry 3.141
                      @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
                      • strawberry 3.141S
                        @pepemujica should be yes. When you enter from a device which gets blocked through the ipwhitelist you get a message in the logs
                        P K 2 Replies Last reply
                          @strawberry-3.141 Still can’t find the way, the whitelist is empty, I can access from the browser where it is installed the MM, but outside that I can’t, even being at the same wifi network :(
                          • K
                            @strawberry-3-141
                            PM2 restart won’t work.
                            Could you have a look, please.
                            Thanks a lot
                            [PM2] PM2 Successfully daemonized
                            │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ watching │
                             Use `pm2 show ` to get more details about an app
                            [PM2][ERROR] Process mm not found
                            { Error: Command failed: pm2 restart mm
                                at ChildProcess.exithandler (child_process.js:218:12)
                                at emitTwo (events.js:106:13)
                                at ChildProcess.emit (events.js:191:7)
                                at maybeClose (internal/child_process.js:877:16)
                                at Socket. (internal/child_process.js:334:11)
                                at emitOne (events.js:96:13)
                                at Socket.emit (events.js:188:7)
                                at Pipe._handle.close [as _onclose] (net.js:493:12) killed: false, code: 1, signal: null, cmd: 'pm2 restart mm' }
                            pi@raspberrypi:~/MagicMirror $
                            • strawberry 3.141S
                              @kurt looks like there is currently no instance running that can be restarted so just start a new one by doing pm2 start mm
                              • K
                                @strawberry-3.141
                                Thank you, this is what I get…
                                pi@raspberrypi:~/MagicMirror $  pm2 start mm
                                [PM2][ERROR] script not found : /home/pi/MagicMirror/mm
                                pi@raspberrypi:~/MagicMirror $ pm2 show
                                  error: missing required argument `id'
                                • strawberry 3.141S
                                  @kurt [PM2][ERROR] script not found
                                  did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                  • K
                                    @strawberry-3.141
                                    yes I did it following the steps in that wiki
                                    • yawnsY
                                      yawns Moderator
                                      Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
                                      So please go back one folder with cd .. or directly with cd ~ and try again
                                      • K
                                        kurt @yawns
                                        @yawns
                                        this is what I get,
                                        do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
                                        in my modules folder there is no PM2 folder. Should there be one?
                                        Thanks a lot for help
                                        kurt
                                        pi@raspberrypi:~ $ npm start
                                        npm ERR! Linux 4.4.50-v7+
                                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                        npm ERR! node v6.10.0
                                        npm ERR! npm  v3.10.10
                                        npm ERR! code ENOENT
                                        npm ERR! errno -2
                                        npm ERR! syscall open
                                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm ERR! enoent This is most likely not a problem with npm itself
                                        npm ERR! enoent and is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/pi/npm-debug.log
                                        pi@raspberrypi:~ $  pm2 start mm
                                        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                        [PM2][ERROR] script not found : /home/pi/mm
                                        │ Name │ mode │ status │ ↺ │ cpu │ memory │
                                        yawnsY 1 Reply Last reply
                                        • yawnsY
                                          yawns Moderator @kurt
                                          @kurt
                                          If you want to start the process with npm start then you have to do that inside ~/MagicMirror
                                          However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                          pm2 seems to be working fine on your raspberry, so I would start here:
                                          Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
                                          cd ~
                                          nano mm.sh
                                          Add the following lines:
                                          DISPLAY=:0 npm start
                                          Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
                                          chmod +x mm.sh
                                          You are now ready to the MagicMirror using this script using PM2.
                                          • K
                                            kurt @yawns
                                            @yawns
                                            my first step was to make this start script following the instructions.
                                            the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
                                            When I try to start the mm by npm start I get this (the mirror is not appearing):
                                            { Error: listen EADDRINUSE :::8080
                                                at Object.exports._errnoException (util.js:1026:11)
                                                at exports._exceptionWithHostPort (util.js:1049:20)
                                                at Server._listen2 (net.js:1253:14)
                                                at listen (net.js:1289:10)
                                                at net.js:1399:9
                                                at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                                at process._tickCallback (internal/process/next_tick.js:98:9)
                                                at Module.runMain (module.js:592:11)
                                                at run (bootstrap_node.js:402:7)
                                                at startup (bootstrap_node.js:157:9)
                                              code: 'EADDRINUSE',
                                              errno: 'EADDRINUSE',
                                              syscall: 'listen',
                                              address: '::',
                                              port: 8080 }
                                            Thank you
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
