    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 946.7k Views 77 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Snille
      @Snille https://github.com/Jopyth/MMM-Remote-Control/blob/master/remote.html#L10 uses the old path
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS
        Snille Module Developer @strawberry 3.141
        @strawberry-3.141 Oh! :) That’s why… Thank you.
          A Former User
          Hey @Jopyth,
          really like your module. By now, it works really cool with the standard definition. Now I try to hide single modules and I’m not so deep into configuring it.
          Would you mind, to post a minimal example of your config file with the calendar show / hide example you have posted with gifs at the top?
          That would be just perfect so I can see, how it’s working.
          Thanks a lot
          Patrick
            McSorley
            Just installed it and its working a treat! Thank you.
            • K
              kurt
              @Jopyth
              strawberry helped me a lot! to install your modul and it works fine, just starting to play around with it. to install moduls in the future without taking care about missing kommas or [ or { or making mistakes by copying scripts, is a imendous help for people like me, who is absolut new to this javascriptpythonworld.
              So thanks a lot and cheers
              by now everything is running fine
              Kurt
              • A
                AAPS
                After updating MM from Remote-Control, when I rebooted I got a black screen. I realized that npm install was necessary, so everything works now. Only I thought that updating from Remote-Control would allow me to completely update without having to touch my mouse and keyboard. Is it supposed to?
                Mykle1M J 2 Replies Last reply Reply Quote 1
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @AAPS
                  @Jopyth
                  If you wouldn’t mind taking a look at this:
                  https://forum.magicmirror.builders/topic/2188/mmm-remote-control-stopped-working-error
                  I didn’t want to double post
                  • G
                    gshimself
                    Dude, I just tried this for the first time.
                    Holy shit, I love it! Nice work!
                    • F
                      fox
                      @Jopyth have you changed something on the screen?
                      Now on the devices the page losts the icons and back buttons etc.
                      Tested on iOS, linux, laptop, handy, tablet. Everywhere the same effect:
                      alt text
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @fox
                        @fox the module didn’t update the path to the icons that has changed in v2.1.1 yet.
                        K F 2 Replies Last reply Reply Quote 0
                        • K
                          kurt @strawberry 3.141
                          @strawberry-3.141
                          how can we update the path?
                          cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
                          Thanke you
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @kurt
                            @kurt as far as i can see it is merged into the dev branch
                            to change to dev branch do the following
                            cd ~/MagicMirror/modules/MMM-Remote-Control
                            git fetch
                            git checkout develop
                            • F
                              fox @strawberry 3.141
                              @strawberry-3.141
                              What do you mean? That I can fix it with an update ?
                                A Former User
                                Can anyone post a example of his config, so I can see what to do to switch on/off the single modules? I only do have the default values there, shutdown etc…
                                Appreciate your help, thx
                                • F
                                  fox @Guest
                                  @PatrickGlatz
                                  You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
                                  So no need to change other modules configs
                                  • K
                                    @strawberry-3.141
                                    thank you, the icons are here again :slight_smile:
                                    I’ll try to install pm2 so I can use the New start and Switch off feature.
                                      pepemujica
                                      Hi @Jopyth !
                                      I’m trying to acces from my smartphone, but I have no answer.
                                      From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
                                      Kind regards
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                        @pepemujica check your whitelist settings
                                          pepemujica @strawberry 3.141
                                          @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
                                          • strawberry 3.141S
                                            @pepemujica should be yes. When you enter from a device which gets blocked through the ipwhitelist you get a message in the logs
                                            P K 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
