    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • SnilleS
      Snille Module Developer @strawberry 3.141
      @strawberry-3.141 Hmm… Can’t get it to work… Even deleted the “node_modules” before doing npm install in the mm dir, then also went in to the “vendor” dir and did the same… Still no pictures in the remote… However, I do get the “fontawesome” icons on other modules (my own included) so the pictures are there. :)
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Snille
        @Snille https://github.com/Jopyth/MMM-Remote-Control/blob/master/remote.html#L10 uses the old path
        SnilleS 1 Reply Last reply
        • SnilleS
          @strawberry-3.141 Oh! :) That’s why… Thank you.
            A Former User
            Hey @Jopyth,
            really like your module. By now, it works really cool with the standard definition. Now I try to hide single modules and I’m not so deep into configuring it.
            Would you mind, to post a minimal example of your config file with the calendar show / hide example you have posted with gifs at the top?
            That would be just perfect so I can see, how it’s working.
            Thanks a lot
            Patrick
              McSorley
              Just installed it and its working a treat! Thank you.
              • K
                kurt
                @Jopyth
                strawberry helped me a lot! to install your modul and it works fine, just starting to play around with it. to install moduls in the future without taking care about missing kommas or [ or { or making mistakes by copying scripts, is a imendous help for people like me, who is absolut new to this javascriptpythonworld.
                So thanks a lot and cheers
                by now everything is running fine
                Kurt
                • A
                  AAPS
                  After updating MM from Remote-Control, when I rebooted I got a black screen. I realized that npm install was necessary, so everything works now. Only I thought that updating from Remote-Control would allow me to completely update without having to touch my mouse and keyboard. Is it supposed to?
                  Mykle1M J 2 Replies Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @AAPS
                    @Jopyth
                    If you wouldn’t mind taking a look at this:
                    https://forum.magicmirror.builders/topic/2188/mmm-remote-control-stopped-working-error
                    I didn’t want to double post
                    • G
                      gshimself
                      Dude, I just tried this for the first time.
                      Holy shit, I love it! Nice work!
                      • foxF
                        fox
                        @Jopyth have you changed something on the screen?
                        Now on the devices the page losts the icons and back buttons etc.
                        Tested on iOS, linux, laptop, handy, tablet. Everywhere the same effect:
                        alt text
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @fox
                          @fox the module didn’t update the path to the icons that has changed in v2.1.1 yet.
                          K foxF 2 Replies Last reply
                          • K
                            kurt @strawberry 3.141
                            @strawberry-3.141
                            how can we update the path?
                            cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
                            Thanke you
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @kurt
                              @kurt as far as i can see it is merged into the dev branch
                              to change to dev branch do the following
                              cd ~/MagicMirror/modules/MMM-Remote-Control
                              git fetch
                              git checkout develop
                              K 1 Reply Last reply
                              • foxF
                                fox @strawberry 3.141
                                @strawberry-3.141
                                What do you mean? That I can fix it with an update ?
                                  A Former User
                                  Can anyone post a example of his config, so I can see what to do to switch on/off the single modules? I only do have the default values there, shutdown etc…
                                  Appreciate your help, thx
                                  foxF 1 Reply Last reply
                                  • foxF
                                    fox @Guest
                                    @PatrickGlatz
                                    You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
                                    So no need to change other modules configs
                                    • K
                                      @strawberry-3.141
                                      thank you, the icons are here again :slight_smile:
                                      I’ll try to install pm2 so I can use the New start and Switch off feature.
                                        pepemujica
                                        Hi @Jopyth !
                                        I’m trying to acces from my smartphone, but I have no answer.
                                        From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
                                        Kind regards
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                          @pepemujica check your whitelist settings
                                          P 1 Reply Last reply
                                            pepemujica @strawberry 3.141
                                            @strawberry-3.141 it is empty, with this any IP is allowed to access, am I right?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 10 / 14
