    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 933.6k Views 77 Watching
      janner6 @Mykle1
      @Mykle1 recommend any other module?
        Mykle1 Project Sponsor Module Developer @janner6
        @janner6 said in [Remote-Control] Shutdown, Configure and Update your MagicMirror:
        Sure, since you’re asking. These three I could not do without
        MMM-Simple-Logo - Bottom left and bottom right
        MMM-Globe - Bottom middle, in between the two SimpleLogo pictures
        MMM-WunderGround - Top right and top middle, under the clock
          janner6 @Jopyth
          @Jopyth hi, sorry to hijack this answer but I was hoping for some advice please? When I installed the MMM-remote I left the configure URL to be displayed on the screen. Unfortunately though I can’t remove it now? Even when I deselect it from the configuration website it will not go away?
          Any ideas?
          • Y Offline
            yawns Moderator @janner6
            @janner6
            did you remove or comment the position attribute?
                module: 'MMM-Remote-Control'
                // , position: 'bottom_left'
              janner6 @yawns
              @yawns I totally forgot about this, thanks for the reminder. Exactly what I wanted.
              • SnilleS Offline
                Snille Module Developer
                @Jopyth I have lost the “Back” button on my remote see pic…
                Update: Just realized I have actually lost all the “icons”… :)
                I’m on the “development” branch (both on the mirror and on your module).
                I have recently reinstalled my mirror (today actually) but before that it worked…
                Have I missed something?
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @Snille
                  @Snille the icons got removed on the dev branch you have to run npm install in the magicmirror directory
                  SnilleS 1 Reply Last reply Reply Quote 0
                  • SnilleS Offline
                    Snille Module Developer @strawberry 3.141
                    @strawberry-3.141 Hmm… Can’t get it to work… Even deleted the “node_modules” before doing npm install in the mm dir, then also went in to the “vendor” dir and did the same… Still no pictures in the remote… However, I do get the “fontawesome” icons on other modules (my own included) so the pictures are there. :)
                      @Snille https://github.com/Jopyth/MMM-Remote-Control/blob/master/remote.html#L10 uses the old path
                      • SnilleS Offline
                        @strawberry-3.141 Oh! :) That’s why… Thank you.
                          A Former User
                          Hey @Jopyth,
                          really like your module. By now, it works really cool with the standard definition. Now I try to hide single modules and I’m not so deep into configuring it.
                          Would you mind, to post a minimal example of your config file with the calendar show / hide example you have posted with gifs at the top?
                          That would be just perfect so I can see, how it’s working.
                          Thanks a lot
                          Patrick
                            McSorley
                            Just installed it and its working a treat! Thank you.
                            • K Offline
                              kurt
                              @Jopyth
                              strawberry helped me a lot! to install your modul and it works fine, just starting to play around with it. to install moduls in the future without taking care about missing kommas or [ or { or making mistakes by copying scripts, is a imendous help for people like me, who is absolut new to this javascriptpythonworld.
                              So thanks a lot and cheers
                              by now everything is running fine
                              Kurt
                                AAPS
                                After updating MM from Remote-Control, when I rebooted I got a black screen. I realized that npm install was necessary, so everything works now. Only I thought that updating from Remote-Control would allow me to completely update without having to touch my mouse and keyboard. Is it supposed to?
                                Mykle1M J 2 Replies Last reply Reply Quote 1
                                  Mykle1 Project Sponsor Module Developer @AAPS
                                  @Jopyth
                                  If you wouldn’t mind taking a look at this:
                                  https://forum.magicmirror.builders/topic/2188/mmm-remote-control-stopped-working-error
                                  I didn’t want to double post
                                  • G Offline
                                    gshimself
                                    Dude, I just tried this for the first time.
                                    Holy shit, I love it! Nice work!
                                    • F Offline
                                      fox
                                      @Jopyth have you changed something on the screen?
                                      Now on the devices the page losts the icons and back buttons etc.
                                      Tested on iOS, linux, laptop, handy, tablet. Everywhere the same effect:
                                      alt text
                                      Issues With MMM-WatchDog known?
                                      https://forum.magicmirror.builders/post/29827
                                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                        strawberry 3.141 Project Sponsor Module Developer @fox
                                        @fox the module didn’t update the path to the icons that has changed in v2.1.1 yet.
                                        K F 2 Replies Last reply Reply Quote 0
                                        • K Offline
                                          kurt @strawberry 3.141
                                          @strawberry-3.141
                                          how can we update the path?
                                          cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
                                          Thanke you
                                            strawberry 3.141 Project Sponsor Module Developer @kurt
                                            @kurt as far as i can see it is merged into the dev branch
                                            to change to dev branch do the following
                                            cd ~/MagicMirror/modules/MMM-Remote-Control
                                            git fetch
                                            git checkout develop
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
