    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • K
      kurt @strawberry 3.141
      @strawberry-3-141
      PM2 restart won’t work.
      Could you have a look, please.
      Thanks a lot
      [PM2] PM2 Successfully daemonized
      │ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ watching │
       Use `pm2 show ` to get more details about an app
      [PM2][ERROR] Process mm not found
      { Error: Command failed: pm2 restart mm
          at ChildProcess.exithandler (child_process.js:218:12)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Socket. (internal/child_process.js:334:11)
          at emitOne (events.js:96:13)
          at Socket.emit (events.js:188:7)
          at Pipe._handle.close [as _onclose] (net.js:493:12) killed: false, code: 1, signal: null, cmd: 'pm2 restart mm' }
      pi@raspberrypi:~/MagicMirror $
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt looks like there is currently no instance running that can be restarted so just start a new one by doing pm2 start mm
        K 1 Reply Last reply
        • K
          @strawberry-3.141
          Thank you, this is what I get…
          pi@raspberrypi:~/MagicMirror $  pm2 start mm
          [PM2][ERROR] script not found : /home/pi/MagicMirror/mm
          pi@raspberrypi:~/MagicMirror $ pm2 show
            error: missing required argument `id'
          • strawberry 3.141S
            @kurt [PM2][ERROR] script not found
            did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
            • K
              @strawberry-3.141
              yes I did it following the steps in that wiki
              • yawnsY
                yawns Moderator
                Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
                So please go back one folder with cd .. or directly with cd ~ and try again
                • K
                  kurt @yawns
                  @yawns
                  this is what I get,
                  do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
                  in my modules folder there is no PM2 folder. Should there be one?
                  Thanks a lot for help
                  kurt
                  pi@raspberrypi:~ $ npm start
                  npm ERR! Linux 4.4.50-v7+
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                  npm ERR! node v6.10.0
                  npm ERR! npm  v3.10.10
                  npm ERR! code ENOENT
                  npm ERR! errno -2
                  npm ERR! syscall open
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is most likely not a problem with npm itself
                  npm ERR! enoent and is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/npm-debug.log
                  pi@raspberrypi:~ $  pm2 start mm
                  [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                  [PM2][ERROR] script not found : /home/pi/mm
                  │ Name │ mode │ status │ ↺ │ cpu │ memory │
                  yawnsY 1 Reply Last reply
                  • yawnsY
                    yawns Moderator @kurt
                    @kurt
                    If you want to start the process with npm start then you have to do that inside ~/MagicMirror
                    However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                    pm2 seems to be working fine on your raspberry, so I would start here:
                    Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
                    cd ~
                    nano mm.sh
                    Add the following lines:
                    DISPLAY=:0 npm start
                    Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
                    chmod +x mm.sh
                    You are now ready to the MagicMirror using this script using PM2.
                    • K
                      kurt @yawns
                      @yawns
                      my first step was to make this start script following the instructions.
                      the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
                      When I try to start the mm by npm start I get this (the mirror is not appearing):
                      { Error: listen EADDRINUSE :::8080
                          at Object.exports._errnoException (util.js:1026:11)
                          at exports._exceptionWithHostPort (util.js:1049:20)
                          at Server._listen2 (net.js:1253:14)
                          at listen (net.js:1289:10)
                          at net.js:1399:9
                          at _combinedTickCallback (internal/process/next_tick.js:77:11)
                          at process._tickCallback (internal/process/next_tick.js:98:9)
                          at Module.runMain (module.js:592:11)
                          at run (bootstrap_node.js:402:7)
                          at startup (bootstrap_node.js:157:9)
                        code: 'EADDRINUSE',
                        errno: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '::',
                        port: 8080 }
                      Thank you
                      • yawnsY
                        yawns Moderator
                        EADDRINUSE means, there is another process running and listening on port 8080
                        It looks like the magicmirror somehow is running already.
                        • K
                          kurt @kurt
                          @yawns
                          By now the PM2 does its work! Great!
                          When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
                          But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
                          So by now some features work :slight_smile: some still need some time or a little push…
                          Thank you
                            pepemujica
                            Hi @mochman !
                            Is there any chance to change the caption that it is shown of each module?
                            For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
                            Is it possible to change the caption in the control?
                            Kind regards
                              Jopyth Moderator @AAPS
                              Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
                              Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
                              [1.1.3] - 2017-04-23
                              Added
                              • Portuguese translation
                              • Indonesian translation
                              • Support for iOS Icon and Webapp
                              Changed
                              • Installation no longer needs a temporary file
                              Fixed
                              • Icon paths adapted to changes in Magic Mirror² 2.1.0
                              Hopefully I got everyone covered in my answers:
                              @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
                              @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
                              @AAPS You are right, I should probably add npm install after updating MM.
                              @pepemujica What error do you get? Maybe it is something in your network settings?
                              P ? 2 Replies Last reply
                                pepemujica @Jopyth
                                @Jopyth Hi! Yes I could solve the part of remote connection, but still can’t find the way to change the name of moddules in the control, since I have for example 3 or 4 iFrames, all of them just says iFrame in the control, so I’m looking the way to customize them. Is it possible?
                                Kind regards
                                J 1 Reply Last reply
                                  A Former User @Jopyth
                                  Hey @Jopyth, yes you are of course totally right. Took a closer look into it and of course it is jut a menu entry. Thanks for the hint.
                                    Jopyth Moderator @pepemujica
                                    @pepemujica Currently not possible. How would you identify them? Do they have different headers? Or by region/position?
                                    P strawberry 3.141S 2 Replies Last reply
                                    • foxF
                                      fox
                                      Hi @Jopyth thank you for your efforts. A question, on mobile device a crazy bug is there. The navigation is not correct because the navigation buttons are not correct and partly dissappeared.
                                      Does anybode have the same issue?
                                      Issues With MMM-WatchDog known?
                                      https://forum.magicmirror.builders/post/29827
                                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                        pepemujica @Jopyth
                                        @Jopyth Actually I have no idea haha
                                        I’ve added a link in the module control section where I can change proffiles with the proffile switcher module, so I thought may be something similar could be done
                                        • foxF
                                          fox
                                          Has anybode an idea why “no modules loaded” ?
                                          alt text
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @Jopyth
                                            @Jopyth maybe something like alias
                                              module: "modulename",
                                              alias: "fancymodule",
                                            then check if alias exists if not display normal module name
                                            P 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
