    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 926.4k Views 77 Watching
    • Y Offline
      yawns Moderator
      Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
      So please go back one folder with cd .. or directly with cd ~ and try again
      K 1 Reply Last reply Reply Quote 1
      • K Offline
        kurt @yawns
        @yawns
        this is what I get,
        do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
        in my modules folder there is no PM2 folder. Should there be one?
        Thanks a lot for help
        kurt
        pi@raspberrypi:~ $ npm start
        npm ERR! Linux 4.4.50-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.10.0
        npm ERR! npm  v3.10.10
        npm ERR! code ENOENT
        npm ERR! errno -2
        npm ERR! syscall open
        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm ERR! enoent This is most likely not a problem with npm itself
        npm ERR! enoent and is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/npm-debug.log
        pi@raspberrypi:~ $  pm2 start mm
        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
        [PM2] PM2 Successfully daemonized
        [PM2][ERROR] script not found : /home/pi/mm
        │ Name │ mode │ status │ ↺ │ cpu │ memory │
         Use `pm2 show ` to get more details about an app
        • Y Offline
          yawns Moderator @kurt
          @kurt
          If you want to start the process with npm start then you have to do that inside ~/MagicMirror
          However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
          pm2 seems to be working fine on your raspberry, so I would start here:
          Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
          cd ~
          nano mm.sh
          Add the following lines:
          DISPLAY=:0 npm start
          Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
          chmod +x mm.sh
          You are now ready to the MagicMirror using this script using PM2.
          • K Offline
            kurt @yawns
            @yawns
            my first step was to make this start script following the instructions.
            the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
            When I try to start the mm by npm start I get this (the mirror is not appearing):
            { Error: listen EADDRINUSE :::8080
                at Object.exports._errnoException (util.js:1026:11)
                at exports._exceptionWithHostPort (util.js:1049:20)
                at Server._listen2 (net.js:1253:14)
                at listen (net.js:1289:10)
                at net.js:1399:9
                at _combinedTickCallback (internal/process/next_tick.js:77:11)
                at process._tickCallback (internal/process/next_tick.js:98:9)
                at Module.runMain (module.js:592:11)
                at run (bootstrap_node.js:402:7)
                at startup (bootstrap_node.js:157:9)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '::',
              port: 8080 }
            Thank you
            • Y Offline
              yawns Moderator
              EADDRINUSE means, there is another process running and listening on port 8080
              It looks like the magicmirror somehow is running already.
              • K Offline
                kurt @kurt
                @yawns
                By now the PM2 does its work! Great!
                When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
                But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
                So by now some features work :slight_smile: some still need some time or a little push…
                Thank you
                  pepemujica
                  Hi @mochman !
                  Is there any chance to change the caption that it is shown of each module?
                  For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
                  Is it possible to change the caption in the control?
                  Kind regards
                    Jopyth Moderator @AAPS
                    Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
                    Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
                    [1.1.3] - 2017-04-23
                    Added
                    • Portuguese translation
                    • Indonesian translation
                    • Support for iOS Icon and Webapp
                    Changed
                    • Installation no longer needs a temporary file
                    Fixed
                    • Icon paths adapted to changes in Magic Mirror² 2.1.0
                    Hopefully I got everyone covered in my answers:
                    @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
                    @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
                    @AAPS You are right, I should probably add npm install after updating MM.
                    @pepemujica What error do you get? Maybe it is something in your network settings?
                    P ? 2 Replies Last reply Reply Quote 1
                      pepemujica @Jopyth
                      @Jopyth Hi! Yes I could solve the part of remote connection, but still can’t find the way to change the name of moddules in the control, since I have for example 3 or 4 iFrames, all of them just says iFrame in the control, so I’m looking the way to customize them. Is it possible?
                      Kind regards
                        [[global:former-user]] @Jopyth
                        Hey @Jopyth, yes you are of course totally right. Took a closer look into it and of course it is jut a menu entry. Thanks for the hint.
                          Jopyth Moderator @pepemujica
                          @pepemujica Currently not possible. How would you identify them? Do they have different headers? Or by region/position?
                          P strawberry 3.141S 2 Replies Last reply Reply Quote 0
                          • F Offline
                            fox
                            Hi @Jopyth thank you for your efforts. A question, on mobile device a crazy bug is there. The navigation is not correct because the navigation buttons are not correct and partly dissappeared.
                            Does anybode have the same issue?
                            Issues With MMM-WatchDog known?
                            https://forum.magicmirror.builders/post/29827
                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              pepemujica @Jopyth
                              @Jopyth Actually I have no idea haha
                              I’ve added a link in the module control section where I can change proffiles with the proffile switcher module, so I thought may be something similar could be done
                              • F Offline
                                fox
                                Has anybode an idea why “no modules loaded” ?
                                alt text
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @Jopyth
                                  @Jopyth maybe something like alias
                                    module: "modulename",
                                    alias: "fancymodule",
                                  then check if alias exists if not display normal module name
                                    pepemujica @strawberry 3.141
                                    @strawberry-3.141 does the alias exist or it’s just an idea?
                                      strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                      @pepemujica well you can put everything in there but alias isnt supported from anything yet, so we could claim it for this and the other configuration modules
                                      • T Offline
                                        twosix
                                        The module is not working for me to any extent, when I whitelist the IPs for my school’s wifi (following the HowToWhitelistIP thread’s directions) in every way stated, I get the “this device is not allowed to access…” message. Then, when I allow all IPs access I get the “cannot get remote/html” message. Any help would be great! Thanks!
                                        • SnilleS Offline
                                          Snille Module Developer
                                          Hi! I’m trying to figure out how to hide/show modules with “REMOTE_ACTION” from “MMM-ModuleScheduler”.
                                          First, here is the remote control “config”.
                                          	module: "MMM-Remote-Control",
                                          		"moduleData":[
                                          			{"identifier":"module_55_MMM-TextClock"},
                                          I know that the “identifier” for the “MMM-TextClock” is correct.
                                          Then in the “MMM-ModuleScheduler” I have this:
                                          	module: "MMM-ModuleScheduler",
                                          		uselock: false,
                                          		notification_schedule: [
                                          			{notification: "REMOTE_ACTION", schedule: "0 11 * * *", payload: {action: 'HIDE {"identifier":"module_55_MMM-TextClock"}'}},
                                          		global_schedule: []
                                          It’s suppose to hide the “MMM-TextClock” at 11 AM but it’s not hiding it.
                                          I do get this in the log at the correct time:
                                          MMM-TextClock received a module notification: REMOTE_ACTION from sender: MMM-ModuleScheduler module.js:115
                                          So the action get sent… But the “MMM-TextClock” still shows… What have I missed?
                                          Or misunderstood? :)
                                          Thank you.
                                          • SnilleS Offline
                                            Hi again! I’ve been using your excellent module since I started my build. And all along I had it in an “IFrame” on the mirror (the IFrame is shown via a touch on a button MMM-ModuleBar). However, about 2 moths ago, your module no longer shows up in the IFrame (it’s just black on the Mirror). However if I use another browser (not Electron) the IFrame shows the Remote Control. Also it shows up “remotely” both if I go directly to the Remote Control address and if I open the full Mirror in another browser.
                                            I’m not sure where the problem is. If it’s on your module or in Electron.
                                            I have another “web-interface” (SONOS Web Interface) in another IFrame showed the same way and that still works.
                                            I’m on the dev branch of MM.
                                            Let me know if you have any ideas… :)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
