    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.6k Views 77 Watching
    • K
      kurt @yawns
      @yawns
      my first step was to make this start script following the instructions.
      the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
      When I try to start the mm by npm start I get this (the mirror is not appearing):
      { Error: listen EADDRINUSE :::8080
          at Object.exports._errnoException (util.js:1026:11)
          at exports._exceptionWithHostPort (util.js:1049:20)
          at Server._listen2 (net.js:1253:14)
          at listen (net.js:1289:10)
          at net.js:1399:9
          at _combinedTickCallback (internal/process/next_tick.js:77:11)
          at process._tickCallback (internal/process/next_tick.js:98:9)
          at Module.runMain (module.js:592:11)
          at run (bootstrap_node.js:402:7)
          at startup (bootstrap_node.js:157:9)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '::',
        port: 8080 }
      Thank you
      K 1 Reply Last reply
      • yawnsY
        yawns Moderator
        EADDRINUSE means, there is another process running and listening on port 8080
        It looks like the magicmirror somehow is running already.
        • K
          kurt @kurt
          @yawns
          By now the PM2 does its work! Great!
          When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
          But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
          So by now some features work :slight_smile: some still need some time or a little push…
          Thank you
            pepemujica
            Hi @mochman !
            Is there any chance to change the caption that it is shown of each module?
            For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
            Is it possible to change the caption in the control?
            Kind regards
              Jopyth Moderator @AAPS
              Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
              Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
              [1.1.3] - 2017-04-23
              Added
              • Portuguese translation
              • Indonesian translation
              • Support for iOS Icon and Webapp
              Changed
              • Installation no longer needs a temporary file
              Fixed
              • Icon paths adapted to changes in Magic Mirror² 2.1.0
              Hopefully I got everyone covered in my answers:
              @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
              @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
              @AAPS You are right, I should probably add npm install after updating MM.
              @pepemujica What error do you get? Maybe it is something in your network settings?
              P ? 2 Replies Last reply
                pepemujica @Jopyth
                @Jopyth Hi! Yes I could solve the part of remote connection, but still can’t find the way to change the name of moddules in the control, since I have for example 3 or 4 iFrames, all of them just says iFrame in the control, so I’m looking the way to customize them. Is it possible?
                Kind regards
                J 1 Reply Last reply
                  A Former User @Jopyth
                  Hey @Jopyth, yes you are of course totally right. Took a closer look into it and of course it is jut a menu entry. Thanks for the hint.
                    Jopyth Moderator @pepemujica
                    @pepemujica Currently not possible. How would you identify them? Do they have different headers? Or by region/position?
                    P strawberry 3.141S 2 Replies Last reply
                    • foxF
                      fox
                      Hi @Jopyth thank you for your efforts. A question, on mobile device a crazy bug is there. The navigation is not correct because the navigation buttons are not correct and partly dissappeared.
                      Does anybode have the same issue?
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                        pepemujica @Jopyth
                        @Jopyth Actually I have no idea haha
                        I’ve added a link in the module control section where I can change proffiles with the proffile switcher module, so I thought may be something similar could be done
                        • foxF
                          fox
                          Has anybode an idea why “no modules loaded” ?
                          alt text
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Jopyth
                            @Jopyth maybe something like alias
                              module: "modulename",
                              alias: "fancymodule",
                            then check if alias exists if not display normal module name
                            P 1 Reply Last reply
                              pepemujica @strawberry 3.141
                              @strawberry-3.141 does the alias exist or it’s just an idea?
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                @pepemujica well you can put everything in there but alias isnt supported from anything yet, so we could claim it for this and the other configuration modules
                                • T
                                  twosix
                                  The module is not working for me to any extent, when I whitelist the IPs for my school’s wifi (following the HowToWhitelistIP thread’s directions) in every way stated, I get the “this device is not allowed to access…” message. Then, when I allow all IPs access I get the “cannot get remote/html” message. Any help would be great! Thanks!
                                  • SnilleS
                                    Snille Module Developer
                                    Hi! I’m trying to figure out how to hide/show modules with “REMOTE_ACTION” from “MMM-ModuleScheduler”.
                                    First, here is the remote control “config”.
                                    	module: "MMM-Remote-Control",
                                    		"moduleData":[
                                    			{"identifier":"module_55_MMM-TextClock"},
                                    I know that the “identifier” for the “MMM-TextClock” is correct.
                                    Then in the “MMM-ModuleScheduler” I have this:
                                    	module: "MMM-ModuleScheduler",
                                    		uselock: false,
                                    		notification_schedule: [
                                    			{notification: "REMOTE_ACTION", schedule: "0 11 * * *", payload: {action: 'HIDE {"identifier":"module_55_MMM-TextClock"}'}},
                                    		global_schedule: []
                                    It’s suppose to hide the “MMM-TextClock” at 11 AM but it’s not hiding it.
                                    I do get this in the log at the correct time:
                                    MMM-TextClock received a module notification: REMOTE_ACTION from sender: MMM-ModuleScheduler module.js:115
                                    So the action get sent… But the “MMM-TextClock” still shows… What have I missed?
                                    Or misunderstood? :)
                                    Thank you.
                                    B 1 Reply Last reply
                                    • SnilleS
                                      Hi again! I’ve been using your excellent module since I started my build. And all along I had it in an “IFrame” on the mirror (the IFrame is shown via a touch on a button MMM-ModuleBar). However, about 2 moths ago, your module no longer shows up in the IFrame (it’s just black on the Mirror). However if I use another browser (not Electron) the IFrame shows the Remote Control. Also it shows up “remotely” both if I go directly to the Remote Control address and if I open the full Mirror in another browser.
                                      I’m not sure where the problem is. If it’s on your module or in Electron.
                                      I have another “web-interface” (SONOS Web Interface) in another IFrame showed the same way and that still works.
                                      I’m on the dev branch of MM.
                                      Let me know if you have any ideas… :)
                                      • chaseb1357C
                                        chaseb1357
                                        I downloaded this module today and its been the best one so far. It has everything in it that I have been trying to accomplish for weeks. I wish I saw this one sooner. I have only one issue, when i click the restart MagicMirror button i get an error and my MagicMirror dose not restart.
                                        foxF 1 Reply Last reply
                                        • foxF
                                          fox @chaseb1357
                                          @chaseb1357 said in [Remote-Control] Shutdown, Configure and Update your MagicMirror:
                                          same to me. this module rocks…! i am for donating with ETH
                                          • K
                                            krisalexroberts
                                            Can you confirm the get URL to hide and show all?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
