    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 946.7k Views 77 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @kurt
      @kurt [PM2][ERROR] script not found
      did you follow these steps to create the script? https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
      • K
        kurt @strawberry 3.141
        @strawberry-3.141
        yes I did it following the steps in that wiki
        • Y
          yawns Moderator
          Shouldn’t pm2 start mm be executed in ~ and not in ~/MagicMirror ? The tutorial said to create mm.sh in ~
          So please go back one folder with cd .. or directly with cd ~ and try again
          K 1 Reply Last reply Reply Quote 1
          • K
            kurt @yawns
            @yawns
            this is what I get,
            do you think it is a good idea to start the install routine once again from the beginning? pi@raspberrypi:~ $
            in my modules folder there is no PM2 folder. Should there be one?
            Thanks a lot for help
            kurt
            pi@raspberrypi:~ $ npm start
            npm ERR! Linux 4.4.50-v7+
            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
            npm ERR! node v6.10.0
            npm ERR! npm  v3.10.10
            npm ERR! code ENOENT
            npm ERR! errno -2
            npm ERR! syscall open
            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm ERR! enoent This is most likely not a problem with npm itself
            npm ERR! enoent and is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /home/pi/npm-debug.log
            pi@raspberrypi:~ $  pm2 start mm
            [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
            [PM2] PM2 Successfully daemonized
            [PM2][ERROR] script not found : /home/pi/mm
            │ Name │ mode │ status │ ↺ │ cpu │ memory │
             Use `pm2 show ` to get more details about an app
            • Y
              yawns Moderator @kurt
              @kurt
              If you want to start the process with npm start then you have to do that inside ~/MagicMirror
              However if you want to use pm2 then I would advise following the instructions again: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
              pm2 seems to be working fine on your raspberry, so I would start here:
              Make a MagicMirror start script. To use PM2 in combination with MagicMirror, we need to make a simple shell script. Preferable, we put this script outside the MagicMirror folder to make sure it won’t give us any issues if we want to upgrade the mirror.
              cd ~
              nano mm.sh
              Add the following lines:
              DISPLAY=:0 npm start
              Save and close, using the commands CTRL-O and CTRL-X. Now make sure the shell script is executable bij performing the following command:
              chmod +x mm.sh
              You are now ready to the MagicMirror using this script using PM2.
              • K
                kurt @yawns
                @yawns
                my first step was to make this start script following the instructions.
                the mm.sh with the script cd ~/MagicMirror DISPLAY=:0 npm start is now in my /home/pi folder.
                When I try to start the mm by npm start I get this (the mirror is not appearing):
                { Error: listen EADDRINUSE :::8080
                    at Object.exports._errnoException (util.js:1026:11)
                    at exports._exceptionWithHostPort (util.js:1049:20)
                    at Server._listen2 (net.js:1253:14)
                    at listen (net.js:1289:10)
                    at net.js:1399:9
                    at _combinedTickCallback (internal/process/next_tick.js:77:11)
                    at process._tickCallback (internal/process/next_tick.js:98:9)
                    at Module.runMain (module.js:592:11)
                    at run (bootstrap_node.js:402:7)
                    at startup (bootstrap_node.js:157:9)
                  code: 'EADDRINUSE',
                  errno: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '::',
                  port: 8080 }
                Thank you
                • Y
                  yawns Moderator
                  EADDRINUSE means, there is another process running and listening on port 8080
                  It looks like the magicmirror somehow is running already.
                  • K
                    kurt @kurt
                    @yawns
                    By now the PM2 does its work! Great!
                    When I put the pi away from electricity and then start the pi again, PM2 starts the mirror :slight_smile:
                    But when I make some changes in Edit modulesor Einstellungen, save them, the changes are not shown, also after restarting the mirror but I get Error!also after restarting the mirror.
                    So by now some features work :slight_smile: some still need some time or a little push…
                    Thank you
                      pepemujica
                      Hi @mochman !
                      Is there any chance to change the caption that it is shown of each module?
                      For example, I’ve got 2 clocks modules, so I can see what time is it in 2 different countries. But when I go to the Remote control I see 2 “Clocks” and don’t know which is the clock I’m hiding or showing until I press the boton.
                      Is it possible to change the caption in the control?
                      Kind regards
                        Jopyth Moderator @AAPS
                        Sorry for my long absence. I am currently in the last weeks of writing my master thesis. Therefore unfortunately not much will be happening until second or third week of May.
                        Big thanks to @strawberry-3-141 and @yawns to help everyone out so much. I finally made a release with the outstanding fixes:
                        [1.1.3] - 2017-04-23
                        Added
                        • Portuguese translation
                        • Indonesian translation
                        • Support for iOS Icon and Webapp
                        Changed
                        • Installation no longer needs a temporary file
                        Fixed
                        • Icon paths adapted to changes in Magic Mirror² 2.1.0
                        Hopefully I got everyone covered in my answers:
                        @PatrickGlatz Have you figured it out yet? I don’t think there is any special configuration needed, just need to find the right menu.
                        @kurt Thanks! Hopefully I will come around to improve the config interface at some point, as there are still some known bugs and problems, but I am glad it is already helping.
                        @AAPS You are right, I should probably add npm install after updating MM.
                        @pepemujica What error do you get? Maybe it is something in your network settings?
                        P ? 2 Replies Last reply Reply Quote 1
                          pepemujica @Jopyth
                          @Jopyth Hi! Yes I could solve the part of remote connection, but still can’t find the way to change the name of moddules in the control, since I have for example 3 or 4 iFrames, all of them just says iFrame in the control, so I’m looking the way to customize them. Is it possible?
                          Kind regards
                            A Former User @Jopyth
                            Hey @Jopyth, yes you are of course totally right. Took a closer look into it and of course it is jut a menu entry. Thanks for the hint.
                              Jopyth Moderator @pepemujica
                              @pepemujica Currently not possible. How would you identify them? Do they have different headers? Or by region/position?
                              P strawberry 3.141S 2 Replies Last reply Reply Quote 0
                              • F
                                fox
                                Hi @Jopyth thank you for your efforts. A question, on mobile device a crazy bug is there. The navigation is not correct because the navigation buttons are not correct and partly dissappeared.
                                Does anybode have the same issue?
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                  pepemujica @Jopyth
                                  @Jopyth Actually I have no idea haha
                                  I’ve added a link in the module control section where I can change proffiles with the proffile switcher module, so I thought may be something similar could be done
                                  • F
                                    fox
                                    Has anybode an idea why “no modules loaded” ?
                                    alt text
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @Jopyth
                                      @Jopyth maybe something like alias
                                        module: "modulename",
                                        alias: "fancymodule",
                                      then check if alias exists if not display normal module name
                                        pepemujica @strawberry 3.141
                                        @strawberry-3.141 does the alias exist or it’s just an idea?
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                          @pepemujica well you can put everything in there but alias isnt supported from anything yet, so we could claim it for this and the other configuration modules
                                          • T
                                            twosix
                                            The module is not working for me to any extent, when I whitelist the IPs for my school’s wifi (following the HowToWhitelistIP thread’s directions) in every way stated, I get the “this device is not allowed to access…” message. Then, when I allow all IPs access I get the “cannot get remote/html” message. Any help would be great! Thanks!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
