    InWall Mirror
    17 Posts 8 Posters 17.8k Views 8 Watching
      DirkS
      Hi folks!
      i wanted to share my InWall MagicMirror after it is finished. But i’m looking for more likes and faves on my facebook site and therefore i’m placing my link here beforehand :D
      https://www.facebook.com/dsdesign2015/
      It is a workers blog of my wife and me how we design our house. Actually we have the biggest project running and the Magic Mirror is a part of it.
      Guess where it will be build in ;)
      I will post pictures here after i finished it. The system is already working a few month but only for development on a desk.
      Would be great if some of you will have a look on our projects and give some likes and shares ;D
      regards
      Dirk
      1 Reply Last reply Reply Quote -2
        DirkS
        As i said, some pictures will come if i start the InWall Mirror.
        Draft where the mirror will be.
        Then cut the Wall
        First cut the Wall
        Big hole :D
        Big hohle
        Much nicer now
        Much nicer now
        With hardware, the Pi has to do some more jobs with the houseautomation
        alt text
        alt text
        The PIR will be mounted next to it within the wall, too
        alt text
        alt text
        The LCD need to be a door for the maintenance ;)
        alt text
        alt text
        alt text
        Yeah need another direction :D
        alt text
        Now waiting for the mirror and frame.
        alt text
        View of the new Kitchen i’m building now with MagicMirror :)
        alt text
        Check out my Facebook Site for the grand construction blog! :D Give some likes and shares if you like it ;)
        1 Reply Last reply Reply Quote 4
          DirkS
          Finally i got the mirror and frame! :D
          The mirror comes from myspiegel.de and the frame has been ordered at bilderrahmen-passt.de.
          alt text
          alt text
          alt text
          alt text
          alt text
          alt text
          alt text
          D slametpsS 2 Replies Last reply Reply Quote 5
            done @DirkS
            @DirkS LOL @ “Na, Zuggerschneggsche!”
            For those who don’t know … hmm, should I call it German? ;P
            This is some deep dialect. Zuckerschnecke -> Sugar snail -> like sweetie or sugar plum ;)
            But this is a nice work!
            I had in mind to hide the socket behind the mirror but you got serious! ;)
            Thumbs up!
            Nice way to “hide” the PIR sensor! :D
              DirkS
              :D it is also the hessisch mirror ^^
                DirkS
                @done try to translate “Geil wuzz!” :D it is impossible, right? :D
                  done @DirkS
                  @DirkS It’s already impossible to translate this in proper German :D
                    DirkS
                    @done hahah! yes that’s right :D
                    that are all the compliments:
                                             morning: [
                                                    "Gumoje, Schnibbelsche!",
                                                    "Scheene Doag!",
                                                    "Ei guude wie?",
                                                    "Wie hoaschde gepennt?",
                                                    "Na du Stinkwatz?"
                                            afternoon: [
                                                    "Na, Schnuggelsche!",
                                                    "Du bischd subber!",
                                                    "Guude!",
                                                    "Gud sieschde aus!"
                                            evening: [
                                                    "Des zischt wie Abbelsaft!",
                                                    "Na, Zuckerschneggsche?",
                                                    "Erbaame! Zu Spät!",
                                                    "Geil Wuzz!"
                    • G Offline
                      gizzmo
                      Very nice build!!
                      Did you do anything for ventilation? I guess it gets warm behind the mirror?
                        DirkS @gizzmo
                        @gizzmo Thanks a lot. I measure the temperatur inside with a DS18B20 sensor to get knowledge about the heating. I do not exceed 32 °C since starting to use it. The next summer i need to see. But the frame is not directly at the wall because of the way of mounting it. So i have 5mm space between and some air can circulate.
                        • Y Offline
                          yesyes
                          Lovely mirror!
                          Quick question about the colours of the light and reflection. I noticed in your pictures that the mirror seems to reflect the complimentary colours of your RGB light (in purple light the reflection of the opposite wall is light blue). Is the mirror doing that or did you have different colours on your RGB LEDs? If it is the mirror, is this noticeable when you look at the mirror or only through the camera?
                            DirkS
                            @yesyes thanks! :D at that time the RGB Led’s had a rainbow effect. It is APA102 and i can switch different effects with hyperion. So that is what you see.
                            • Y Offline
                              yesyes @DirkS
                              @DirkS Ah, OK, I thought you may have addressable LEDs but wanted to make sure. I have lots of RGB LED strips in my house too and was a bit worried that I would have to put the mirror in a “white LED only” area. ;-)
                              • DocVooDooD Offline
                                DocVooDoo
                                Yeah! Thats the best :-)
                                Great Job!
                                • cowboysdudeC Offline
                                  cowboysdude Module Developer
                                  Just wow… fantastic job!!!
                                  • slametpsS Offline
                                    slametps @DirkS
                                    @DirkS awesome!!!
                                    regards,
                                    Slamet PS
                                    • H Offline
                                      hayman
                                      This post is deleted!
