    MMM-GoogleAssistant and MMM-AssistantMk2 installation issues :(
    mmm-googleassistantmmm-assistantmk2google assistantassistant
    20 Posts 4 Posters 9.1k Views 4 Watching
      Davidpearl1
      @Sean Still not working and I still get the 500 error
      I have followed all steps and have the credentials and everything
      I am using an RPI 3B+ with stretch, could that be an issue?
      I have tried creating a new set of credentials and that didn’t work either
      The API is enabled - I am just completely lost now :(
      • ? Offline
        A Former User @Davidpearl1
        @davidpearl1 give me your node version. and can you show me your credentials.json (with changing the private secret strings to something others)
        And error messages also.
          Davidpearl1
          @Sean
          pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ node -v
          v9.11.2
          {“installed”:{“client_id”:“999952555594-iu5vlompjfib9s3bc3tdsh981f3hfulk.apps.googleusercontent.com”,“project_id”:“mmm-assistant-e6cac”,“auth_uri”:“https://accounts.google.com/o/oauth2/auth",“token_uri”:“https://accounts.google.com/o/oauth2/token”,“auth_provider_x509_cert_url”:“https://www.googleapis.com/oauth2/v1/certs”,“client_secret”:“xxxxxxxx”,“redirect_uris”:[“urn:ietf:wg:oauth:2.0:oob”,"http://localhost”]}}
          Error message is a google website with error 500 -
          "500. That’s an error.
          There was an error. Please try again later. That’s all we know."
          • ? Offline
            @davidpearl1
            credentails itself seems to have no problem.
            And I think it is not the kind of the problem of API enable/disable.
            500 error usually, be occurred when authentication is denied by Google for some reasons. With googling, there seem several cases;
            1. Just hiccup. try later for a while.
            2. Your client_id is contaminated. (I don’t know what it is and why)
            Sorry, I can not reproduce your error so I cannot catch what’s wrong.
              Davidpearl1
              Thats rubbish :(
              So I technically cannot use the module at all! is there a way to manually authorise it?
              The only thing I can think about is starting again from scratch
              does it allow you to get the auto code from Google now? could it be a google side issue?
              • ? Offline
                @davidpearl1
                I cannot assure anything. Some googling says that could be a temporal problem, but others say your auth might have some problem (but I don’t know what exactly).
                I suggest removing your whole google-projects and try again from scratch. The only thing I can suspect is, you had a conflict with your some google-projects and used the other credentials for your different projects. (I think that case would be not also. but I have no idea at all…)
                  Davidpearl1
                  I got it to work!!! :D:D:D:D:D
                  I deleted all other projects and combined it into one, I also deleted all of my devices and started a new one.
                  My issue now is I haven’t had a ‘Token.json’ file generate in the directory?
                  • ? Offline
                    @davidpearl1
                    After auth, token.json should be generated in the directory where credentials.json is located. isn’t there?
                      Davidpearl1
                      @Sean nope :(
                        Davidpearl1
                        just re-ran it and its showing lol :S
                        WHAT IS UP WITH MY PI!!! lol
                        Now I just need to figure out how to use and apply the basic configuration
