    MMM-GoogleAssistant and MMM-AssistantMk2 installation issues :(
    mmm-googleassistantmmm-assistantmk2google assistantassistant
    20 Posts 4 Posters 8.9k Views 4 Watching
      A Former User @Davidpearl1
      @davidpearl1 give me your node version. and can you show me your credentials.json (with changing the private secret strings to something others)
      And error messages also.
        Davidpearl1
        @Sean
        pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ node -v
        v9.11.2
        {“installed”:{“client_id”:“999952555594-iu5vlompjfib9s3bc3tdsh981f3hfulk.apps.googleusercontent.com”,“project_id”:“mmm-assistant-e6cac”,“auth_uri”:“https://accounts.google.com/o/oauth2/auth",“token_uri”:“https://accounts.google.com/o/oauth2/token”,“auth_provider_x509_cert_url”:“https://www.googleapis.com/oauth2/v1/certs”,“client_secret”:“xxxxxxxx”,“redirect_uris”:[“urn:ietf:wg:oauth:2.0:oob”,"http://localhost”]}}
        Error message is a google website with error 500 -
        "500. That’s an error.
        There was an error. Please try again later. That’s all we know."
          @davidpearl1
          credentails itself seems to have no problem.
          And I think it is not the kind of the problem of API enable/disable.
          500 error usually, be occurred when authentication is denied by Google for some reasons. With googling, there seem several cases;
          1. Just hiccup. try later for a while.
          2. Your client_id is contaminated. (I don’t know what it is and why)
          Sorry, I can not reproduce your error so I cannot catch what’s wrong.
            Davidpearl1
            Thats rubbish :(
            So I technically cannot use the module at all! is there a way to manually authorise it?
            The only thing I can think about is starting again from scratch
            does it allow you to get the auto code from Google now? could it be a google side issue?
              @davidpearl1
              I cannot assure anything. Some googling says that could be a temporal problem, but others say your auth might have some problem (but I don’t know what exactly).
              I suggest removing your whole google-projects and try again from scratch. The only thing I can suspect is, you had a conflict with your some google-projects and used the other credentials for your different projects. (I think that case would be not also. but I have no idea at all…)
                Davidpearl1
                I got it to work!!! :D:D:D:D:D
                I deleted all other projects and combined it into one, I also deleted all of my devices and started a new one.
                My issue now is I haven’t had a ‘Token.json’ file generate in the directory?
                  @davidpearl1
                  After auth, token.json should be generated in the directory where credentials.json is located. isn’t there?
                    Davidpearl1
                    @Sean nope :(
                      Davidpearl1
                      just re-ran it and its showing lol :S
                      WHAT IS UP WITH MY PI!!! lol
                      Now I just need to figure out how to use and apply the basic configuration
                        @davidpearl1
                        If you want to invoke your Assistant with voice, you need also MMM-Hotword and MMM-notificationTrigger.
                        Good luck to you.
