    MMM-GoogleAssistant and MMM-AssistantMk2 installation issues :(
    mmm-googleassistantmmm-assistantmk2google assistantassistant
    20 Posts 4 Posters 10.6k Views 4 Watching
      A Former User @Davidpearl1
      @davidpearl1
      I cannot assure anything. Some googling says that could be a temporal problem, but others say your auth might have some problem (but I don’t know what exactly).
      I suggest removing your whole google-projects and try again from scratch. The only thing I can suspect is, you had a conflict with your some google-projects and used the other credentials for your different projects. (I think that case would be not also. but I have no idea at all…)
        Davidpearl1
        I got it to work!!! :D:D:D:D:D
        I deleted all other projects and combined it into one, I also deleted all of my devices and started a new one.
        My issue now is I haven’t had a ‘Token.json’ file generate in the directory?
          @davidpearl1
          After auth, token.json should be generated in the directory where credentials.json is located. isn’t there?
            Davidpearl1
            @Sean nope :(
              Davidpearl1
              just re-ran it and its showing lol :S
              WHAT IS UP WITH MY PI!!! lol
              Now I just need to figure out how to use and apply the basic configuration
                @davidpearl1
                If you want to invoke your Assistant with voice, you need also MMM-Hotword and MMM-notificationTrigger.
                Good luck to you.
                • X
                  Xintium
                  @davidpearl1 How did you fix it I also tried to delete my project and recreate it but it did not help. And what do you mean you deleted all other projects and combined it into one?
                    Davidpearl1 @Xintium
                    @xintium I deleted all of my projects on Google Cloud and combined all the API’s and services I needed into one project.
                    Once I had done that it fixed my issue
                    X 1 Reply Last reply Reply Quote 0
                    • X
                      Xintium @Davidpearl1
                      @davidpearl1 I got it working. Now I am stuck because when using electron-rebuild it fails, did you also have problems using electron-rebuild.
                        @xintium I ended up moving away from this module and compiled a brand new image using Latest Raspbian build and installing GassistPi and then MagicMirror
                        This works perfectly and the instructions are super easy to follow
                        Not taking away from these modules as they look excellent but they were just too fiddly for me - GassistPi has installers which does all the hard work for you
                          mrega @Guest
                          @sean Go to “console.cloud.google.com”, then to “Api and Services”, select your project, then “Credentials”, then “OAuth Consent Screen”, indicate your E-mail address, try again "node auth_and_test.js "and tell us!
                          Here are the steps you must do before asking for authorization;
                          https://developers.google.com/assistant/sdk/guides/library/python/embed/config-dev-project-and-account
                          Specifically in;
                          Configure the Developer Project and Account Settings and Register the Device Model.
                          Luck! Come back with your feedback!
