    Adding jQuery
    11 Posts 5 Posters 9.2k Views 5 Watching
      snimax
      Okey thank you very much!
      • E Offline
        E3V3A
        @strawberry-3-141
        It seem that getscripts doesn’t work anymore, at least not as I expected. This seem to be because even though MM finds the script, we get hit by the security error:
        The resource from “http://192.168.1.2:8080/node_modules/jquery-ui-dist/jquery-ui.css” was blocked due to MIME type mismatch (X-Content-Type-Options: nosniff).
        Any idea how to get past this?
        "Everything I do (here) is for free – altruism is the way!"
        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
        • N Offline
          ninjabreadman @E3V3A
          @E3V3A When I look up the error, I find this thread which says:
          Check if the file path is correct and the file exists - in my case that was the issue - as I fixed it, the error disappeared.
          I suspect that jQuery is installed in your module’s node_modules folder, and not at the root of your MagicMirror (I may however be wrong).
          In which case I would expect jQuery to be installed at “http://192.168.1.2:8080/modules/MMM-Tabulator/node_modules/jquery-ui-dist/jquery-ui.css”. This is why in your thread here you needed to use this.file() so that it created a relative path.
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          • E Offline
            E3V3A @ninjabreadman
            @ninjabreadman Oh man, Excellent! I wish I’d had seen that a week ago…
            Anyway, I’ve solved it since, but got another issue with getting the Tabulator code to actually do something. No errors shown, unfortunately.
            PS. Is there a way to close a thread or mark it as solved??
            yawnsY 1 Reply Last reply Reply Quote 0
            • yawnsY Offline
              yawns Moderator @E3V3A
              @E3V3A
              Yes, at the end of the thread there is a button with a gear symbol. Tap/click it and select Mark as question, then tap/click a second time and select Mark as resolved
              • E Offline
                E3V3A @yawns
                @yawns I must be blind!?
                • yawnsY Offline
                  @E3V3A
                  No, I guess it’s my mistake. As a moderator I have these options. And I think the thread starter has the option as well.
