CALENDAR_EVENTS not broadcasting? MMM-Calendarweek
Hey so I’m trying to make an app do something if it receives the notification ‘CALENDAR_EVENTS’ from the calendar.
So far its not doing anything. I tried to use the alert module but I get nothing from that either. If MMM-CalendarWeek isnt properly working with broadcasts, is there a way to set up the stock calendar module to work in the background?
My code is here
// Default module config. defaults: { this.hide(), text: "Calendar alert receieved!" }, notificationReceived: function(notification, payload, sender) { if (notification === 'CALENDAR_EVENTS') { var x = payload, for (let value of x) { this.show(), var startTime = new Date(startDate), var endTime = new Date(endDate), var ms = (endTime.getTime() - startTime.getTime()) / 1000, setTimeout(function(){ this.hide() }, ms), } } }, // Override dom generator. getDom: function() { var wrapper = document.createElement("div"); wrapper.innerHTML = this.config.text; return wrapper; } }); -
@subintro one of my modules depends on the calendar notification and works fine
And you’re using the MMM-Calendarweek module? Does my notificationReceived look like it should be working to you?
@subintro no, using the default calendar module, and your code looks exactly like mine for handling the event
@sdetweil Ah darn, I can’t understand why its not working then.
I’ve put the default calendar module in the background but doesnt seem like its working. I’m lost with this haha.
Thanks for the help
So I’ve updated my code to make it as simple as possible, but I’m still not getting anything.
I’ve tried adding console.log to my calendar module so when it sends the notification, it logs it so I can see it actually working, but for some reason the calendar breaks when I do that.
// Default module config. defaults: { text: "Notification received!"; this.hide; }, notificationReceived:function(notification, payload, sender) { if (notification === 'CALENDAR_EVENTS') { this.show(); this.updateDom(); } },So I believe this should be working if the calendar events is being sent out.
Is there any other way I can check the notifications are sending without console.log?
@Subintro
If you install the MMM-Remote-Control module you are able to simulate notifications. The link for doing that has to look like: http://IPofYourMM:8080/remote?action=NOTIFICATION& notification=CALENDAR_EVENTSI would also put a console.log before your
this.show();in your code:
if (notification === 'CALENDAR_EVENTS') { console.log("Calenderevent received."); this.show(); this.updateDom(); }AxLED
You should use Log.log() in the module instead of console.log()…
Then open the debug console, ctrl-shift-i letter i)… select the console tab
@axled said in CALENDAR_EVENTS not broadcasting? MMM-Calendarweek:
console.log(“Calenderevent received.”);
Oh man this has been massive help. Looks like my module isnt receiving notifications at all. Time to figure it out
Man I think I misunderstood how the broadcast events works, I was understanding that when an event started, it broadcasted that one event as it started. I was hoping I could make a pop-up notification system for when an event starts, and disappear when it ends.
Thats what it seems like looking at the calendar console logs
