    CALENDAR_EVENTS not broadcasting? MMM-Calendarweek
    13 Posts 4 Posters 7.2k Views 3 Watching
      Subintro
      Hey so I’m trying to make an app do something if it receives the notification ‘CALENDAR_EVENTS’ from the calendar.
      So far its not doing anything. I tried to use the alert module but I get nothing from that either. If MMM-CalendarWeek isnt properly working with broadcasts, is there a way to set up the stock calendar module to work in the background?
      My code is here
      	// Default module config.
      	defaults: {
      		this.hide(),
      	text: "Calendar alert receieved!"
      				if (notification === 'CALENDAR_EVENTS') {
      				var x = payload,
      				for (let value of x) {
      					this.show(),
      				var startTime = new Date(startDate),
      				var endTime = new Date(endDate),
      				var ms = (endTime.getTime() - startTime.getTime()) / 1000,
      				setTimeout(function(){
      					this.hide()
      					}, ms),
      	// Override dom generator.
      	getDom: function() {
      		wrapper.innerHTML = this.config.text;
      		return wrapper;
        sdetweil @Subintro
        @subintro one of my modules depends on the calendar notification and works fine
          Subintro
          And you’re using the MMM-Calendarweek module? Does my notificationReceived look like it should be working to you?
            sdetweil @Subintro
            @subintro no, using the default calendar module, and your code looks exactly like mine for handling the event
              Subintro
              @sdetweil Ah darn, I can’t understand why its not working then.
              I’ve put the default calendar module in the background but doesnt seem like its working. I’m lost with this haha.
              Thanks for the help
                Subintro
                So I’ve updated my code to make it as simple as possible, but I’m still not getting anything.
                I’ve tried adding console.log to my calendar module so when it sends the notification, it logs it so I can see it actually working, but for some reason the calendar breaks when I do that.
                	defaults: {
                	text: "Notification received!";
                	this.hide;
                	notificationReceived:function(notification, payload, sender) {
                					this.show();
                					this.updateDom();
                So I believe this should be working if the calendar events is being sent out.
                Is there any other way I can check the notifications are sending without console.log?
                  AxLed Module Developer
                  @Subintro
                  If you install the MMM-Remote-Control module you are able to simulate notifications. The link for doing that has to look like: http://IPofYourMM:8080/remote?action=NOTIFICATION& notification=CALENDAR_EVENTS
                  I would also put a console.log before your
                  this.show();
                  in your code:
                     console.log("Calenderevent received.");
                     this.show();
                     this.updateDom();
                  AxLED
                    You should use Log.log() in the module instead of console.log()…
                    Then open the debug console, ctrl-shift-i letter i)… select the console tab
                      Subintro
                      @axled said in CALENDAR_EVENTS not broadcasting? MMM-Calendarweek:
                      console.log(“Calenderevent received.”);
                      Oh man this has been massive help. Looks like my module isnt receiving notifications at all. Time to figure it out
                        Subintro
                        Man I think I misunderstood how the broadcast events works, I was understanding that when an event started, it broadcasted that one event as it started. I was hoping I could make a pop-up notification system for when an event starts, and disappear when it ends.
                        Thats what it seems like looking at the calendar console logs
                          It’s just one event, ‘here are the calendar “events” I found that match the configured environment’
                          That’s what I see in my module
                          case “CALENDAR_EVENTS”:
                          this.processEvents(payload);
                          • H Offline
                            heskja Module Developer @sdetweil
                            Author of MMM-CalendarWeek here. I can confirm that the module is broadcasting the event as expected, unless you manually disable it in the module configuration page.
                            As you discovered, the module will broadcast all events available in one array, sorted on startdate as can be seen in the source code here.
                            • H Offline
                              heskja Module Developer @heskja
                              Would also appreciate you marking the issue as solved, as this is not an issue with the MMM-CalendarWeek module :) Thanks!
