Unsolved CALENDAR_EVENTS not broadcasting? MMM-Calendarweek
It’s just one event, ‘here are the calendar “events” I found that match the configured environment’
That’s what I see in my module
case “CALENDAR_EVENTS”:
this.processEvents(payload); -
Author of MMM-CalendarWeek here. I can confirm that the module is broadcasting the event as expected, unless you manually disable it in the module configuration page.
As you discovered, the module will broadcast all events available in one array, sorted on startdate as can be seen in the source code here.
Would also appreciate you marking the issue as solved, as this is not an issue with the MMM-CalendarWeek module :) Thanks!
