    CALENDAR_EVENTS not broadcasting? MMM-Calendarweek
    13 Posts 4 Posters 6.6k Views 3 Watching
      Subintro
      @sdetweil Ah darn, I can’t understand why its not working then.
      I’ve put the default calendar module in the background but doesnt seem like its working. I’m lost with this haha.
      Thanks for the help
        Subintro
        So I’ve updated my code to make it as simple as possible, but I’m still not getting anything.
        I’ve tried adding console.log to my calendar module so when it sends the notification, it logs it so I can see it actually working, but for some reason the calendar breaks when I do that.
        	// Default module config.
        	defaults: {
        	text: "Notification received!";
        	this.hide;
        	notificationReceived:function(notification, payload, sender) {
        				if (notification === 'CALENDAR_EVENTS') {
        					this.show();
        					this.updateDom();
        So I believe this should be working if the calendar events is being sent out.
        Is there any other way I can check the notifications are sending without console.log?
          AxLed Module Developer
          @Subintro
          If you install the MMM-Remote-Control module you are able to simulate notifications. The link for doing that has to look like: http://IPofYourMM:8080/remote?action=NOTIFICATION& notification=CALENDAR_EVENTS
          I would also put a console.log before your
          this.show();
          in your code:
             console.log("Calenderevent received.");
             this.show();
             this.updateDom();
          AxLED
            sdetweil
            You should use Log.log() in the module instead of console.log()…
            Then open the debug console, ctrl-shift-i letter i)… select the console tab
              Subintro
              @axled said in CALENDAR_EVENTS not broadcasting? MMM-Calendarweek:
              console.log(“Calenderevent received.”);
              Oh man this has been massive help. Looks like my module isnt receiving notifications at all. Time to figure it out
                Subintro
                Man I think I misunderstood how the broadcast events works, I was understanding that when an event started, it broadcasted that one event as it started. I was hoping I could make a pop-up notification system for when an event starts, and disappear when it ends.
                Thats what it seems like looking at the calendar console logs
                  sdetweil
                  It’s just one event, ‘here are the calendar “events” I found that match the configured environment’
                  That’s what I see in my module
                  case “CALENDAR_EVENTS”:
                  this.processEvents(payload);
                  • H Offline
                    heskja Module Developer @sdetweil
                    Author of MMM-CalendarWeek here. I can confirm that the module is broadcasting the event as expected, unless you manually disable it in the module configuration page.
                    As you discovered, the module will broadcast all events available in one array, sorted on startdate as can be seen in the source code here.
                    • H Offline
                      heskja Module Developer @heskja
                      Would also appreciate you marking the issue as solved, as this is not an issue with the MMM-CalendarWeek module :) Thanks!
