    Can't Install Dependencies
    3 Posts 2 Posters 3.0k Views 2 Watching
    • T Offline
      TBC_RC21
      I’m trying to install MM on a clean install of Raspbian (using a Raspberry Pi 3B) and my installation keeps crashing when it tries to update/install the dependencies. Below is the output from the terminal of the install. Originally I was having the issue in this here. I installed both nodejs, npm, and node-semver. After I installed those and reran the MM install (using the instructions here), I now get the errors below. I’ve had the magic mirror software on this pi before, but I can’t figure out what I’m doing wrong this time.
      Cloning MagicMirror Done!
      Installing dependencies …
      (node:4677) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN deprecated express-ipfilter@0.3.1: This package is no longer being maintained and contains security vulnerabilities
      npm ERR! Error: Method Not Allowed
      npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this entire log,
      npm ERR! including the npm and node versions, at:
      npm ERR! http://github.com/npm/npm/issues
      npm ERR! System Linux 4.14.84-v7+
      npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      node ./download-chromedriver.js
      phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/jshint/node_modules/phantomjs-prebuilt
      node install.js
      PhantomJS not found on PATH
      Unexpected platform or architecture: linux/arm
      It seems there is no binary available for your platform/architecture
      Try to install PhantomJS globally
      npm WARN This failure might be due to the use of legacy binary “node”
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm WARN optional dep failed, continuing phantomjs-prebuilt@2.1.16
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
      npm ERR!
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • ? Offline
        [[global:former-user]] @TBC_RC21
        @tbc_rc21
        npm version 1.4 seems quite not so high.
        • T Offline
          TBC_RC21
          Thanks that was it! I’m not sure how I managed to install such an old version. Incase anyone else has this issue, I followed the instructions here to install the current version.
