    Brand new install failing: bash: line 112: npm: command not found
    5 Posts 4 Posters 2.6k Views 3 Watching
    • K Offline
      Kelemvor
      I’m trying to install MM by following this guide:
      https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
      After running the bash command to actually install it, it ends with this error:
      Cloning MagicMirror Done!
      Installing dependencies …
      I saw some things onlien that said to try it again a couple times but that didn’t help. Also saw something about going into the MM folder and running npm start but that doesn’t work either.
      I installed the latest Noobs Full version so don’t know if something is missing or what.
      Any help would be much appreciated.
      Thanks!
      S bheplerB 2 Replies Last reply Reply Quote 0
        sdetweil @Kelemvor
        @kelemvor you need to install npm and node.
        See [node/npm instructable](https://www.instructables.com/id/Install-Nodejs-and-Npm-on-Raspberry-Pi/#discuss
        • bheplerB Offline
          bhepler Module Developer @Kelemvor
          @kelemvor said in Brand new install failing: bash: line 112: npm: command not found:
          There’s your problem. The Magic Mirror works with Raspian, not with Noobs. Download the latest version of Raspian, flash it to your SD card and go from there.
          One note: the command to uninstall a bunch of stuff is a little outdated. You can remove the “penguinspuzzle” entry from that command.
          • K Offline
            Kelemvor
            I thought Noobs was just an easy installer. I chose Raspbian Full from the Noobs menu and thought I was just getting Raspbian. I’ll go get straight Raspbian and see what happens.
            Does it matter if I get Raspbian Lite, Raspbian Desktop or Raspbian Desktop w/recommended software?
              Mykle1 Project Sponsor Module Developer @Kelemvor
              @kelemvor
              I don’t think you want the Lite version. Raspbian Desktop, yes.
