    MMM-Assistantmk2
    11 Posts 2 Posters 3.6k Views 2 Watching
    • F Offline
      fri4end @Guest
      @sean
      Here’s what it says
      		module: "MMM-AssistantMk2",
      		position: "bottom",
      		config:
      			useScreen: true,
      			youtubeAutoplay: true,
      			responseAlert: false,
      			alertError: false,
      			pauseOnYoutube:false,
      			deviceLocation:
      				coordinates:
      					latitude: 37.57,
      					longitude: 126.98
      			profiles:
      				"default":
      					lang: "en-EN"
      			notifications:
          				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
      				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
      			onIdle: {
      timer: 1000 * 30, // in 30sec after last Assistant Query, command “PAGE_1” will be activated.
      command: “PAGE_1”
      onActivate: { //When you wakeup Assistant, command "PAGE_2" will be activated.
         timer: 0,
        command: "PAGE_2"
      command: {
         "PAGE_1": {
         notificationExec: {
            notification: "PAGE_CHANGED",
            payload: 0
      "PAGE_2": {
         notificationExec: {
            payload: 1
      ? F 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @fri4end
        @fri4end
        So, onIdle or onActivate doesn’t work? or not your expectation?
        • F Offline
          fri4end @fri4end
          This post is deleted!
          • F Offline
            fri4end @Guest
            @sean
            No, onIdle and onActivate operate normally
            We checked the status using the notification viewer module.
            Manual operation below
            Below, when onActivate
            I think the payload return is incorrect.
            ? 2 Replies Last reply Reply Quote 0
            • ? Offline
              @fri4end
              Ah, I got it.And I’ve found what was wrong. Wait a min. I’ll patch for it. I assumed each payload should be object type.
              • ? Offline
                @fri4end
                fixed. git pull and try again.
                • F Offline
                  fri4end @Guest
                  @sean
                  It works well. Thank you very much.^^
