    Timer on Module
    22 Posts 4 Posters 7.4k Views 4 Watching
      dsmtweaker
      I am very new to using Java, as my background is only in VB.
      I am trying to add a timer to a module, in this case the MMM-HTMLVideo module. Basically instead of the video just looping(default) I wanted to make the video play at set intervals, say every 5 minutes, etc.
      I tried adding the following code to the MMM-htmlvideo.js, but nothing loads, nor do I see any errors in nps start dev
      // Override dom generator.
      		getDom: function() {
      				var intervalID = window.setInterval(GetVid, 60000);
      				var video =  document.createElement("video");
      			function GetVid() {
      				video.src = this.config.videoSRC;
      				video.autoplay = true;
      				video.loop = this.config.loop;
      				return GetVid;
      S ? 4 Replies Last reply Reply Quote 0
        sdetweil @dsmtweaker
        @dsmtweaker do ctrl-shift-i to open the dev console, and then select the console tab
          @dsmtweaker it would be setInterval (this.GetVid,…)
            @dsmtweaker also think the getVid routine return is wrong
            • ? Offline
              [[global:former-user]] @dsmtweaker
              @dsmtweaker
              getDom() is not good position for your job. That function will be called at anytime when it is needed to redraw your module by MM, not by you. You don’t know when it will be executed on which condition.
              Instead direct calling getDom, use updateDom(). Whenever you call ‘this.updateDom()’, MM will execute your getDom() and redraw your module with result of getDom()
              Then, with setInterval(), you can repeat updateDom as your wish.
              Of course, setInterval and updateDom should move out of getDom. So to where?
              start() isn’t good also. My suggestion is, to create function yourJob() and put setInterval and uodateDom into yourJob(). Then call it by notification - “DOM_OBJECT_CREATED”.
                dsmtweaker @Guest
                @sean So, should I be putting the updateDom in a function? Such as…
                				var intervalID = window.setInterval(this.GetVid, 60000);
                			function GetVid() {
                				updateDom
                • ? Offline
                  @dsmtweaker
                  I’ve added in prior post. Sorry I’m typing on my phone. So I cannot write long…
                  • ? Offline
                    job: function() {
                      setInterval(()=>{
                        this.updateDom() // this will execute your getDom()
                      }, yourInterval)
                    notificationReceived: function (noti, payload, sender) {
                      if (noti == “DOM_OBJECT_CREATED”) this.job()
                    getDom: function () {
                      //making  your video DOM here.
                      dsmtweaker @Guest
                      @sean Sorry for being so new at this. And thank you for all of the help. I tried using your code.
                      get: function() {
                      setInterval(()=>{this.updateDom()}, 60000)
                      notificationRecieved: function (noti, payload, sender) {
                      if (noti = “DOM_OBJECT_CREATED”) this.job()
                      getDom: function ()
                      But I get “Uncaught SyntaxError: Unexpected token (” from notificationRecieved: function (noti, payload, sender) {
                        @dsmtweaker you missed some of the job function
                        this.updateDom()
                        }, yourInterval)
                          dsmtweaker @sdetweil
                          @sdetweil It is there in the get:function
                           get: function() {setInterval(()=>{this.updateDom()}, 60000)
                          		if (noti = "DOM_OBJECT_CREATED") this.job()
                          getDom: fuction ()
                            @dsmtweaker i hate code posting on this forum…
                            note that
                            getDom: fuction () is spelled wrong
                            and also missing the open brace
                              sdetweil
                              there are 3 routines (functions)… in seans post
                              // worker function
                              job: function() {
                                // start a recurring timer that will tell MM to get the module updated dom content
                                // this uses an inline function, be careful of braces and parens  matching
                                setInterval(()=>{
                                  this.updateDom() // this will execute your getDom(), after 'yourInterval' time
                                }, yourInterval)
                              // the function called when notifications are received from the system
                                 // if the notification is "dom is created", then call our worker function
                              // the function called for the module to provide its dom content
                                @sdetweil I made all the corrections noted.
                                but on if (noti == “DOM_OBJECT_CREATED”) this.job() I am still getting the error SyntaxError: Invalid or unexpected token
                                Mykle1M S 2 Replies Last reply Reply Quote 0
                                  Mykle1 Project Sponsor Module Developer @dsmtweaker
                                  @dsmtweaker said in Timer on Module:
                                  Excuse me for jumping in but the curly quotes containing DOM_OBJECT_CREATED will cause that error. Try:
                                  if (noti == "DOM_OBJECT_CREATED") this.job()
                                  The difference is slight, but enough.
                                    @dsmtweaker its the darned cut/paste of the double quotes… in the web posting it shows the MS word document style quotes which cause an error with the javascript parser…
                                    overtype those double quotes with the text editor…
                                    • ? Offline
                                      I’m back. Sorry for my prior mistypo and unsufficient post. I was typing that on my phone.
                                      start: function() {
                                        this.timer = null
                                        this.videoDom = null
                                        var container =  document.createElement("div")
                                        video.id = "VIDEO"
                                        video.style.display = "none"
                                        container.appendChild(video)
                                        this.videoDom = video
                                        return container
                                      // Just create DOMs in getDom(). It's better to control DOMs outside of getDom().
                                      notificationReceived: function(noti, payload, sender) {
                                        if (noti == "DOM_OBJECT_CREATED") this.work()
                                      //DOM_OBJECT_CREATED would be the best time to start your job. Your DOM would be created and be ready to work on that message.
                                      work: function(src = null, interval = null) {
                                        clearTimer(this.timer)
                                        interval = (interval) ? interval : this.config.interval
                                        src = (src) ? src : this.config.videoSRC
                                        this.playVideo(src)
                                        this.timer = setTimeout(()=>{
                                          this.work()
                                        }, interval)
                                      //setTimeout is better than setInterval.
                                      // you can repeat this function by interval. you can change interval and src with parameters of this function.
                                      playVideo: function(src) {
                                        this.videoDom.src = src
                                        if (this.videoDom.style.display == "none") this.videoDom.style.display = "block"
                                        this.videoDom.play()
                                        // assign src to your videoDom and play it.
                                      Not tested on real device, so maybe somthig is missed, but this is basic approach.
                                      I didn’t use updateDom because there is no need to redraw whole module just for playing video.
                                        dsmtweaker @Guest
                                        @sean Thank you, and everyone else for all the help. It’s refreshing to find a forum that doesn’t automatically start bashing beginners.
                                        I think my knowledge is just not ready for something this advanced yet. I used your code, and tried changes here and there to make it work, but still no luck. I am no longer getting any errors in the console. But nothing happens(ie- no video ever loads/plays) this is where I got the code so far…
                                        Module.register(“MMM-htmlvideo”,{
                                        // Default module config.
                                        defaults: {
                                        	videoSRC: 'https://www.mid-americantitle.com/wp-content/uploads/output_HD7205.mp4',
                                        	loop: true,
                                        // get stylesheet
                                        getStyles: function() {
                                        	return ["htmlvideo.css"];
                                        start: function() {
                                          this.timer = null
                                        video.id = "VIDEO"
                                         return container
                                         interval = (interval) ? interval : 30000
                                          this.playVideo(src)
                                           this.work()
                                          }, interval)
                                        I tried changing “interval” with actual numbers, as well as changing the source in multiple locations. Still just get a black screen.
                                        • ? Offline
                                          @dsmtweaker
                                          Sorry there were another mistypes. DOM_OBJECT_CREATED => DOM_OBJECTS_CREATED (and clearTimer => clearTimeout)
                                          use this. tested.
                                          Module.register("test",{
                                            defaults: {
                                              loop: true,
                                              interval: 36000,
                                            start: function() {
                                              this.timer = null
                                              video.id = "VIDEO"
                                              return container
                                              if (noti == "DOM_OBJECTS_CREATED") this.work()
                                              clearTimeout(this.timer)
                                              this.playVideo(src)
                                                this.work()
                                              }, interval)
                                          Anyway, your video is already repeating by loop: true, why you need to repeat it with timer?
                                            dsmtweaker @Guest
                                            @sean You are a genius, thank you so much.
                                            Extra bonus, do you know of anyway to use a local source, instead of a web source?
                                            IE- videoSRC: “/home/pi/content/videos/video1.mp4”
                                            It’s not necessary, I just figured running something locally instead of from the web
                                            would help reduce lag/buffer/tearing etc.
