    MMM-Buttons keine Reaktion?
    3 Posts 1 Posters 1.5k Views 1 Watching
    • R
      robiv8
      Hello,
      is there a log where i can see if something happens when the button press.
      Have MMM buttons run on the Raspi and a pushbutton on Ground and pin 11 (gpio17) plugged.
      Nothing reacts when I push? Do i still have to adjust something?
      Hallo,
      wo gibts denn ein log wo mann schauen kann ob sich was regt beim button drücken.
      Habe MMM-Buttons am laufen und am Raspi ein Pushbutton auf Ground und Pin 11 (gpio17) gesteckt.
      Nix reagiert? Muss ich noch was anderes einstellen oder einschalten?
      MMM-PageSelect läuft auch damit ich mehrere Seiten habe.
      buttons: [
                      pin: 11, //The pin that connects your first button
                      name: "Hauptseite", //Or whatever you really want
                      longPress: { //longPress or shortPress doesnt matter. Really it's just the stuff on the inside that matters.
                          notification: "PAGE_SELECT",
                          payload: "haupt" //Or whatever page you want
      shortPress: {
                          payload: "zweite" //Or whatever page you want
      Danke
      • R
        robiv8
        with a python.py and this code:
        import RPi.GPIO as GPIO
        import time
        GPIO.setwarnings(False) # Ignore warning for now
        GPIO.setmode(GPIO.BOARD) # Use physical pin numbering
        GPIO.setup(11, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
        tries = 0
        while (tries < 200):
            if GPIO.input(11):
                print("11 Open")
            else:
                print ("Close")
            time.sleep(1.)
            tries = tries + 1
        #GPIO.cleanup()           # clean up GPIO on normal exit
        With this code I can see that the button works and triggers.
        But in magicmirror pm2 log mm it shows no reaction!
        Do i have to adjust something else?
        Thanks and a happy new year 2019
        • R
          robiv8
          OK it was the pin!
          The correct PIN number is really impossible ;-)
          But it is very confusing with pin BCM and BOARD
          So the BOARD PIN is correct.
