    MMM-solar showing "Loading" and is doing nothing .... did someone get it running?
    12 Posts 4 Posters 5.3k Views 3 Watching
      MWel1977
      I’m having trouble to get the module “MMM-Solar” to work as it should.
      There are only 3 things needed to configure the module and I have all 3 of them in the config.js file. The API-key, my userID and my systemID.
      But on running the MM2 the module only displays “Loading…”.
      I feel like I’m missing a step! I feel like I need to connect my Enphase system to my API-account. But I have no idea how or even if that is needed.
      Is there someone who got this module to work and wants to help me?
      Or is there a way to get in touch with the module creator so I can ask him what I’m doing wrong?
        sdetweil
        restart the mirror with
        npm start dev
        to open the developers console, then select the console tab,
        are there any errors shown?
          MWel1977 @sdetweil
          @sdetweil … WOW! :fearful_face: :fearful_face: :fearful_face:
          Didn’t know about this! Looks nice!
          But back to the problem…in the console tab I can see some errors but not about the Solar module. There are 2 warnings that the Solar module got a notification from another module but don’t think that’s a problem.
          I can see 3 errors for the modules: MMM-Buienradar, weatherforcast (openweathermap is unauthorized yet it works fine) and for my crypto coins chart (it can’t find cryptocoin picture/logo’s in a specific folder).
          So the Solar-module should work fine looking at this.
            sdetweil
            ok, can u find the console window where you did npm start dev, and see if there are errors reported there? alt-tab, should bring up a list of windows, so you can select the right console window
              MWel1977 @sdetweil
              I’m not seeing any errors but I see something strange…
              Down at the bottomit says:
              Sockets connected & moduls started …
              Launching application.
              Then a bit futher down a line reads:
              Notification: GET_SOLAR Payload: [object object]
              Looks like it’s missing data that it needs to find somewere. Am I right?
                sdetweil @MWel1977
                @mwel1977 thats just bad logging
                edit the node_helper.js file in the MMM-Solar folder, at the end
                after this
                if (!error && response.statusCode == 200) {
                					var jsonData = JSON.parse(body);
                				        self.sendSocketNotification("SOLAR_DATA", jsonData);
                add this
                				else{
                				   if(error!=null){
                					console.log("api request error ="+ JSON.stringify(error));
                				   else{
                					console.log("api response code error ="+ response.statusCode);
                i get this
                Notification: GET_SOLAR Payload: [object Object]
                api response code error =401
                401 is authentication failed
                bheplerB M 2 Replies Last reply Reply Quote 1
                  sdetweil
                  I submitted that code to the MMM-Solar author for the future
                  • bheplerB Offline
                    bhepler Module Developer @sdetweil
                    @sdetweil - Just FYI for everyone: 401 is an Unauthorized Request error message. For some reason, your combination of API key, userID and systemID are not working.
                      sdetweil @bhepler
                      @bhepler I know. I don’t have a key. So it should fail. I was just giving an example of the improved error reporting to help out
                        MWel1977 @sdetweil
                        @sdetweil I’ll try it tonight.
                        Been busy last couple of days (sadly not with my MM2).
                        But I think it has something to do with the API not being able to connect to my solarpanel system. Like I mentionent before.
                          sdetweil @MWel1977
                          @mwel1977 cool… let us know what you find out…
                          I don’t know anything about the solar panel system
                            mash55 @MWel1977
                            @mwel1977 Did you go to the authorization link on your developer portal? Do you see the app you created in the developer portal in your Enlighten site (under Account)?
