    MMM-YrThen - stuck on loading
    5 Posts 2 Posters 1.8k Views 2 Watching
    • M
      madmike
      Hello. A newbie on these forums.
      I had YrNow up and running, but eventually I found one that resembles more what I’d like out of my weather service - YrThen. First problem came when I tried to git clone the repository. I’ll recreate the procedure to see if I did any mistakes.
      cd ~/MagicMirror/modules
      Followed by
      git clone https://github.com/fmandal/MMM-YrThen
      Then normally it’d clone and be done with it, but now it asks for a username and password for Github.com. No matter what I type in it says repo not found or something along those lines. So I decided to download the zip file and add it to /MagicMirror/modules through the file folder and then edit the config.js to add;
      	module: 'MMM-YrThen',
      	position: 'top_right',
      But that ends up with an eternal “Loading…” showing up. The YrNow on the other hand loads fine.
      Anyone care to help a helpless soul?
      • M
        madmike
        Okay, weird. Seems restarting my RPI did the trick… Can the issue be loading both YrThen and YrNow at the same time? I blocked out the YrNow module before rebooting and now YrThen loaded fine. So I went into the config.js to enable the YrNow as well - but then that module is stuck in a loading loop.
        • T
          THeStigh @madmike
          @madmike Hi mate, I’ve been using both at the same time, no tricky tricks :)
          • M
            madmike
            Magically it fixed itself over night - apparently a 24 hour loading time for YrNow in combination with YrThen? :face_with_stuck-out_tongue_closed_eyes:
            • T
              THeStigh @madmike
              @madmike Perhaps slow loading time due to heavy weather conditions in Norway atmo :D
              No, seriously - it always loads immediately here, dunno what you’re doing “wrong”. After a restart of the mirror, is it loading at normal speed?
