MMM-YrThen - stuck on loading
5 Posts 2 Posters 1.5k Views 2 Watching
    madmike
    Hello. A newbie on these forums.
    I had YrNow up and running, but eventually I found one that resembles more what I’d like out of my weather service - YrThen. First problem came when I tried to git clone the repository. I’ll recreate the procedure to see if I did any mistakes.
    cd ~/MagicMirror/modules
    Followed by
    git clone https://github.com/fmandal/MMM-YrThen
    Then normally it’d clone and be done with it, but now it asks for a username and password for Github.com. No matter what I type in it says repo not found or something along those lines. So I decided to download the zip file and add it to /MagicMirror/modules through the file folder and then edit the config.js to add;
    	module: 'MMM-YrThen',
    	position: 'top_right',
    But that ends up with an eternal “Loading…” showing up. The YrNow on the other hand loads fine.
    Anyone care to help a helpless soul?
      madmike
      Okay, weird. Seems restarting my RPI did the trick… Can the issue be loading both YrThen and YrNow at the same time? I blocked out the YrNow module before rebooting and now YrThen loaded fine. So I went into the config.js to enable the YrNow as well - but then that module is stuck in a loading loop.
      T 1 Reply Last reply Jan 9, 2019, 10:14 PM Reply Quote 0
      • T Offline
        THeStigh @madmike
        @madmike Hi mate, I’ve been using both at the same time, no tricky tricks :)
          madmike
          Magically it fixed itself over night - apparently a 24 hour loading time for YrNow in combination with YrThen? :face_with_stuck-out_tongue_closed_eyes:
          T 1 Reply Last reply Jan 11, 2019, 10:27 AM Reply Quote 0
          • T Offline
            THeStigh @madmike
            @madmike Perhaps slow loading time due to heavy weather conditions in Norway atmo :D
            No, seriously - it always loads immediately here, dunno what you’re doing “wrong”. After a restart of the mirror, is it loading at normal speed?
